Forum: Addons
Topic: Title GFX 1 - Page: 1
geposted Wed 11 Jul 18 @ 12:06 pm
Amazing work. Thank you very very much!!!
Hi dj-in-norway
I have a question. How can I delete it white circle on the coverart?
Thank you for your response.
It's okay now. I gave it a black color :)
VJ Python wrote :
Hi dj-in-norway
Probably would be enough to remove the mask part in the <coverart> code in the xml.
But i'll add some variants with square cover to the download asap ;-)
dj-in-norway wrote :
VJ Python wrote :
Hi dj-in-norway
I did it this way. The result is the same. Edit xml do not know :)
Sorry dj-in-norway, but I have another question.
How can I change the text in "current song" Blue-Dark Modern Arty [no remix - with coverart].xml
Thanks for your time!
Hello friend - after download -install is successfull, I choosed type of video skins - but nothing to do....and all videoskins not work now
Have you enabled the videoskin? Have you loaded and played a track whilst checking the video output?
video skins are enabled
a sorry- now is running - thank you :) supppeeeer
Another question - How can I change the text in "current song" after edit in XML - nothing is happened - there is still current song text
and second question - is possible to set longer time visibility titler??
and last question - why sometimes is visible year of song - that is OK and sometimes not???? My format name of song is for exmple: Baby come back (1969) and this year between () sometimes is visible and sometime not I dont know why
thanks
edit - current song - is running olee :))
Why is the display messy code???
Resolved ^_^The encoding is not UTF8.
it is famouse version titler ... I discovered where is possible to edit time to view of text...... :)
[quote=VJ Python]Hi dj-in-norway
would be nice to have a choice of duration location of the title just like The TITLE that was built in VDJ last version
Good work!!
I'm using this skin on 80's MTV style.
It's possible to do but you have to hack the XML file.
I have mine set to come on after 45 seconds and stay live for 30 seconds.
42%
