Forum: Addons
Topic: Controller 2020 by DennYo - Page: 18
Denny DennYo wrote :
THANKS for over 200.000 Downloads of my "Controller" Skin.
That's more than 200,000
x Thank You's
x Hugs
x Dreams realised
You are doing something, right !
If you want this Skinner to stay with us, consider making a small donation to him, there is a lot of work involved
Paypal address: paypal.me/dennyo88
is there a deck option for this pad mode view in the 4 deck vertical? Thanks!
Not at the moment.
Not at the moment.
Thanks!
Version History 3.3.4 - 2022/11/02
Bugfix - Position correctures
add - Wave Variation "split Wave" for all 4 Deck Variations with Botton/Top Wave 1. ("Wave Button"/Wave Size/4 Deck split)
add - toggle Sandbox Button to RampStopTime ("Skin Button"/Top Zone/toggle Sandbox & RampStopTime)
add - change the Jog to a Video Player
add - Pad view 4 Button ("Skin Button"/Deck Setup/PAD 4 BTN)
change - 4 Deck vertical small, full size when you use the option "Center off"
change - 4 Deck vertical, full size when you use the option "Center off"
change - color changes Browser all Color Schemes
change - litle color changes
Version History 3.3.4b - 2022/11/02
Bugfix - Position correctures 4 BTN PADs
change - Master Color from yellow to bluegrey
This is fantastic!. When does it go live?..or put in the extensions so we can get it?
Thanks again!
Supporters get the Update direct after upload here. I send these per Mail.
Here comes the update after check the Skin by Atomix-VirtualDJ.
ohhh..okay..thanks!
Just wanted to Thank You Denn Yo, for your hard work and creativity. This is the only skin that made me switch from the Default VDJ Skin to a Custom.
Definitely your custom skin is off charts a Home Run, I'm loving it.
Thank You
Version 3.3.4b is online
Could you please tell me the location of the font sizes on the text document for the cue points? Or at least the fontsize and i can search by that. I am wanting to enlarge the font of the cue numbers on the wave forms. Thanks for your time.
There are many Positions to Change. You must Search your favorite used Wave:
for every Wave Size one
define class="scratchwavemainextrasmall"
define class="scratchwavemainextrasmallhalf"
define class="scratchwavemainsmall"
define class="scratchwavemainsmallhalf"
define class="scratchwavemainmiddle"
define class="scratchwavemainmiddlehalf"
define class="scratchwavemainlarge"
define class="scratchwavemainlargehalf"
define class="scratchwavemainextralarge"
define class="scratchwavemainextralargehalf"
define class="scratchwavemixervertical"
define class="scratchwavemixerhorizontal"
you can find this Tags 3 Times
1. Font Size Normal -> textsize-define-normal---
2. Font Size Bigger -> textsize-define-large---
3. Font Size extra Big -> textsize-define-extra-large---
change the Fontsize
<text dx="9" dy="-2" fontsize="11"/>
<define class="scratchwavemainextrasmall" orientation="horizontal" placeholders="*width,overlayx,background,backgroundshaded,gridpos" colorVocal="wavevocal" colorInstru="waveinstru" colorBeat="wavebeat" colorNoVocal="wavenovocal" colorNoInstru="wavenoinstru" colorNoBeat="wavenobeat">
<size width="[WIDTH]" height="20"/>
<grid mirrored="yes" pos="[GRIDPOS]"color="wavegridcolor" maincolor="wavegridcolormain" backgroundcolor="waveshadow" background="[BACKGROUND]" backgroundshaded="[BACKGROUNDSHADED]" height="3" size="1" mainsize="3" shapemirrored="both"/>
<gridlines width="1" color="wavegridcolor" transparency="0.5"/>
<cue y="-4" height="28">
<mask width="13" height="28" x="179" y="407"/>
</cue>
<overlay>
<size width="1" height="30"/>
<pos x="+[WIDTH]/2" y="-5"/>
<background shape="square" color="waveoverlaycolor"/>
</overlay>
</define>
change the Fontsize
</cue>
<overlay>
</overlay>
</define>
Thank you so so much!
J J Zrn wrote :
[quote=Denny DennYo]There are many Positions to Change. You must Search your favorite used Wave:
change the Fontsize
</cue>
<overlay>
</overlay>
</define>
I changed these font sizes ( I changed all font sizes from 11) however the font size of the cues on the waveforms are still very small.
i change in this Tag the fontsize from 11 to 16 and the Font is bigger.
    <define class="scratchwavemainsmall" orientation="horizontal" placeholders="*width,overlayx,background,backgroundshaded,gridpos" colorVocal="wavevocal" colorInstru="waveinstru" colorBeat="wavebeat" colorNoVocal="wavenovocal" colorNoInstru="wavenoinstru" colorNoBeat="wavenobeat">
<size width="[WIDTH]" height="40"/>
<grid mirrored="yes" pos="[GRIDPOS]"color="wavegridcolor" maincolor="wavegridcolormain" backgroundcolor="waveshadow" background="[BACKGROUND]" backgroundshaded="[BACKGROUNDSHADED]" height="6" size="1" mainsize="3" shapemirrored="both"/>
<cue y="-9" height="58">
<mask width="13" height="58" x="179" y="407"/>
</cue>
<overlay>
<size width="1" height="60"/>
<pos x="+[WIDTH]/2" y="-10"/>
</overlay>
</define>
which "Text Font Size" do you use in the Skin?
</cue>
<overlay>
</overlay>
</define>
Thanks!..Found it!...this helped.
When you found your personal favorite Size. Tell me this please. I can integrate this native for you.
Version 3.3.5 - 2022/11/30
Bugfix - TAP Button Icon was on Deck right extra Big no Cover not visible
Bugfix - BPM on Jog dark when BPM smaller 100
Bugfix - on Variation 2 big the Filter Value and resonance textzone on same place
Bugfix - Jog Design 3 Color Scheme dark grey
add - german translation for the Skin & Wave Menu
add - new Deck Color grey-blue only "my new favorite" ("Skin Button"/Skin Color Scheme/Deck Color)
add - toggle the Master Volume Knob on Topzone to a Fader ("Skin Button"/Top Zone/toggle Master Volume)
add - toggle the Event Button to a Stems Button ("Skin Button"/Top Zone/Event or Stems)
add - new Variation 2 Deck simple Video ("Skin Button"/Skin Variation/2 Deck simple Video)
add - toggle Volume & Pitch Fader on 2 Deck simple Video on Mixer Video ("Skin Button"/Center/toggle Pitch & Volume Fader)
add - toggle the PAD Highlight Background to Deck Color ("Skin Button"/Skin Color Scheme/PAD Highlight)
add - Prelisten near Searchbar ("Skin Button"/Browser/Prelisten - near Searchbar)
add - Deck Border Song end blink ("Skin Button"/Deck Setup/Border Song end blink)
add - show the Deck Video FX on the Loop Area ("Skin Button"/Deck Setup/LOOPs)
add - hide the Cue Colors on the Cue Buttons ("Skin Button"/Deck Setup/Cue Color)
add - stronger played mark at the Songpos Wave ("Skin Button"/Song Position Wave/stronger played mark)
add - full high played mark at halve height Songpos Wave, when CUEs on Songpos Wave
add - 32/64 Beats Marker at Songpos Wave ("Skin Button"/Song Position Wave/Beat Marker)
add - Songpos Wave Song end blink ("Skin Button"/Song Position Wave/Song end blink)
add - 2. Layout for the Deckinfos on 4 Deck vertical small ("Skin Button"/Song Infos/Deckinfos - 4 Deck vertical small)
add - Song ready Hook (Stems) before the Title in the Songinfo Area ("Skin Button"/Song Infos/Song Ready Hook before Title (Stems))
69%
