Thanks for your hard work, I love it !
geposted Fri 02 Dec 22 @ 9:36 pm
Ditto!
geposted Sat 03 Dec 22 @ 12:48 am
Hi Dennyo
Great work on the skin and the updates. Some questions:
- how do I save the skin settings and transfer them to another laptop? Is there a way to do it without touching the settings.xml?
- secondly Is it possible to make an option to have the CUSTOM BUTTON BAR knobs on the right? (I use the knob for sampler volume and like this it's a bit far away ;-)
![](/img/370409/27452/virtualDJ request.png)
geposted Mon 05 Dec 22 @ 2:22 pm
Hi Timm,
Fist Point: At the moment is the best way to copy the VirtualDJ Setting "VDJScriptGlobalVariables".
I will add an "preset save" function but at the moment i have no idea.
Second Point: this is no problem to add.
geposted Mon 05 Dec 22 @ 2:38 pm
Version 3.3.5 is online
geposted Mon 05 Dec 22 @ 2:45 pm
DennYo Beats wrote :
Hi Timm,
amazing! Thanks a lot Dennyo! Much appreciated.
geposted Tue 06 Dec 22 @ 4:11 pm
Hi Denny-
one small request :
could we please have a Loop indicator (if in loop & how many beats ) on the new 2 deck simple video skin ?
thanks a lot
great skin as always !
one small request :
thanks a lot
geposted Tue 06 Dec 22 @ 6:20 pm
Hi,
the Variation "2 deck simple video" is a wish from a user, he paid for this.
Post a Screenshot with the best place for the loop section and i will see.
geposted Tue 06 Dec 22 @ 6:30 pm
that would be great !
thanks a lot !
thanks a lot !
geposted Tue 06 Dec 22 @ 6:32 pm
Any chance you could work on a custom skin for the Denon sc5000/6000 series screens.
I'm sure it would rival the default skin in a big way
geposted Wed 07 Dec 22 @ 1:12 am
if you give me one, better two SC6000 :D.
Sorry i can't create a skin that i not can testing.
geposted Wed 07 Dec 22 @ 3:05 pm
romeodan wrote :
Hi Denny-
one small request :
and also a small 3 fx section..
thanks a lot
one small request :
thanks a lot
geposted Mon 12 Dec 22 @ 7:23 am
You can use the Custombutton near the Hotcues for indicate the Effects.
![](/img/370856/45898/Screenshot 2022-12-12 091643.png)
geposted Mon 12 Dec 22 @ 8:17 am
Hi,
Really.. well I have a wish Im willing to pay for.
geposted Mon 12 Dec 22 @ 3:36 pm
Post your wish and i will see. Pay is only via donation. Amount is, what it is worth to you.
geposted Mon 12 Dec 22 @ 3:51 pm
It's the 2 deck's small variation. I want this as my go-to because the browser is larger. It just doesn't have some things like the /2 x2 buttons, removing the labels deck 1, and deck 2 gives space for that, then just put a 1 or 2in the upper left corners. The pad page section, a small version, could fit where the empty spaces are on the outer areas of the deck, especially if the artwork area is removed might also leave space for a small version of the effects section. Volume meters next to the bpm readout above the deck options or next to it which would make the meters side-by-side. Also, being all these options are around the deck information area it can also have a 4deck version.
geposted Mon 12 Dec 22 @ 4:31 pm
can you post a simple edited screenshot, please.
geposted Mon 12 Dec 22 @ 4:41 pm
![](/img/370956/41449/deckexample.jpg)
I forgot to add the 1 and 2 deck labels but they can go between the loop and bpm. the small size wont matter because its all about seeing feedback. I'm not suggesting those exact button designs just showing what functions and where to be placed.
geposted Tue 13 Dec 22 @ 10:47 am
I don't have a request however would like to make a donation to you, where does one go to make this donation?
geposted Tue 13 Dec 22 @ 10:56 am
I will see what i can do. Give me a little Time.
geposted Tue 13 Dec 22 @ 12:38 pm
