Forum: Addons
Topic: Controller 2020 by DennYo - Page: 22
Line 13.418 - This is when you use my song position wave --> Skin button /Song Position Wave / custom songpos
change the 15000ms to 30000ms, the blink 250ms is the blinking frequency you can change this to 500ms
<visual class="squaresongpos" x="+0" y="+0" width="[WIDTH]" height="[HEIGHT]" visibility="play && songpos_remain 15000ms && blink 250ms"/>
Line 13.433 - This is when you not use --> Skin button /Song Position Wave /custom songpos
geposted Sun 05 Feb 23 @ 7:26 pm
Thanks for your respond. I'll give it a try.!!!
geposted Sun 05 Feb 23 @ 7:28 pm
iT works to perfections. Thanks.!!!
geposted Sun 05 Feb 23 @ 7:48 pm
The problem is. You must change this after any update from me. When you send me your VDJ Username and the two lines with your changes than i can add this for you. And only you have the changes. Other Users have the normal blink. The Wave blink (15 seconds) on Automix is an Bug from me. I have deactivate blinking at Automix, now.
You can find the correct Username on VirtualDJ Settings/Licenses
geposted Sun 05 Feb 23 @ 8:02 pm
DennYo Beats wrote :
Discussion about Controller 2020 by DennYo
I noticed there is a lock button at the top of the scrren, I clicked it and it locked the screen with just a display that says Dennyo Beats etc. I cannot for the life of me figure out how to unlock it. Closing the program and repoening did not work. Need some assist please and thank you :)
geposted Sun 19 Feb 23 @ 4:45 pm
Nevermind, i finally found something online that helped me. Thank you for making this amazing skin. I downloaded it the first day I ever used virtual dj, and haven't switched to anything else ever since. :)
geposted Sun 19 Feb 23 @ 4:55 pm
You need 3 clicks to unlock:
1. click on DJ (RED area)
2. click on VI (YELLOW area)
3. click on RTUAL (GREEN area)
geposted Sun 19 Feb 23 @ 6:47 pm
Hello, need some help here. I am using your skin with the latest version of VDJ as I am a subscriber. If I can get this to work properly, gladly would like to donate to the cause.
Can you help me though, when I turn on stems, it isn't working. I'm not getting stems for eq, any type, soundwise, and the mixer section does not change to stems either.
Another note that would be incredibly useful if it can be developed, a clean 4 deck, on top with vertical scratch waves aligned under each corresponding deck. for me, particularly, I use the Xone 96 mixer in a 3,1,2,4 configuration, a Xone k2 or two of them, or a K2 and a Dj Tech Tools Twister. and have tested Dj pro ai with that and love it. I use the Xone 96 mixer and would like to just be able to control stems with the K2 and the twister. Would kill to have that configuration here with VDJ as I am loving the sound quality
If I am missing something, please point me in the right direction!
geposted Thu 23 Feb 23 @ 9:23 pm
Version 3.3.8 - 2023/02/26
Bugfix - SAVE/LOAD Preset 1 work not correct
Bugfix - loop load on the Cue Area don't work correct
Bugfix - Songpos Wave at the Cue Window won't show
Bugfix - Volume Fader Lines Deck 1 on Mixer "2 Deck big + 2 Deck small"
add - Camalot KEY Color in the Deck Song Infos ("Skin Button"/Song Infos/KEY Color)
add - bigger Text size of the Song Infos ("Skin Button"/Song Infos/Info Text Size)
add - new PAD desing("Skin Button"/Skin Design/PADs)
add - new CUE desing("Skin Button"/Skin Design/CUEs)
add - PAD Layout 9-16 and 1-16 (click on the Text 1-8, 8-16, 1-16 or use script*)
add - hide the yellow Line when setting "writeHistory" off ("Skin Button"/Browser/Prepare Mode)
add - a third Beatcounter with beatdiff on Topzone ("Skin Button"/Top Zone/Beatcounter 1/2/3)
add - quick setting menus on the area names "HOTCUES" "LOOP" "EFX" "PADS"
add - new variation "4 Deck vertical performance 2" ("SKIN Button"/Skin Variation/4 Deck vertical performance 2)
change - Code of the PADs
change - Variation Center/Mixer off --> "Big" "Middle" "Small" "Big - bigger view" "Middle - bigger view"
change - Topzone buttons rearranged
change - Topzone buttons now move when any element where hide
change - VU Meters from img.png to vector elements
change - Betcounter 16 from img.png to vector element
change - ratio 4 button from img.png to vector element
change - rename "4 Deck vertical small" to "4 Deck vertical performance"
* set '%pad1620' 0 - PAD 1-8
* set '%pad1620' 1 - PAD 9-16
* set '%pad1620' 2 - PAD 1-16
geposted Sun 26 Feb 23 @ 1:53 pm
geposted Sun 26 Feb 23 @ 6:22 pm
Love the new features and tweaks. And thanks for adding the ability to see pads 9-16, and really digging the small footprint of the 1-16 pads buttons.
The Beat Diff indicator is a nice feature, too.
geposted Mon 27 Feb 23 @ 3:13 pm
Help?
geposted Mon 27 Feb 23 @ 4:35 pm
I find something strange in v3.3.8 skin.
I am missing the 'vertical line' [marker] for CUE-points, in ClassicWave Overlap.
I cannot see the 'vertical line' [marker] to see where the CUE-point is exactly.
(Sometimes, I just use the markers only with different colours )
geposted Tue 28 Feb 23 @ 7:00 am
Version 3.3.9 - 2023/02/28
Bugfix - Cue Marker on the Classic Wave wasn't visible
geposted Tue 28 Feb 23 @ 8:50 am
hey
first i want to thank you for that amazing skin!!!!!
geposted Thu 02 Mar 23 @ 11:23 pm
Nice skin... Nice Work... How can i change the BPM decimals in the Jogwheel? from 2 to 1
geposted Tue 14 Mar 23 @ 9:45 pm
hi
i love your work
i have one problem...
randomly font text (ex. eq mid, bass or in/out) starts to tremble or instead of english is Chinese
i try reduce fps but is not that......
any idea???
thanks
geposted Tue 14 Mar 23 @ 10:47 pm
The only way is edit the skin.xml
geposted Wed 15 Mar 23 @ 11:46 am
Sorry, never seen this on my system and no other tell me that.
geposted Wed 15 Mar 23 @ 11:47 am
geposted Thu 16 Mar 23 @ 10:25 pm
89%
