@Tasos that's not an issue of this skin, looks like a driver or HW issue for you alone.
geposted Thu 16 Mar 23 @ 11:59 pm
Yes Loco, .... :)
@Tasos
There are no Chinese chars. I think this are rendering problems. I see you have shrink the Skin to a resolution smaller than 1920x1080 and not 16:9. The Platters are oval and not round.
(The problem with the Oval shrink comes from my Breaklines. i will change this soon)
You can test the VirtualDJ Option experimentalSkinEngine
@Tasos
geposted Fri 17 Mar 23 @ 9:16 am
this happen only in that skin
mac book pro 2013 i5 16gr ram macos catalina
geposted Fri 17 Mar 23 @ 10:16 pm
DennYo Beats wrote :
Yes Loco, .... :)
@Tasos
@Tasos
how to fix the resolution of the skin?
i test the VirtualDJ Option experimentalSkinEngine same....
geposted Fri 17 Mar 23 @ 10:19 pm
update status
i check that issue in an other laptop same settings....
the same think and only in that skin.....
geposted Thu 23 Mar 23 @ 10:08 pm
Version 3.4.0 - 2023/04/04
add - Ask The DJ Message Counter on the Browser Zoom Button (set askTheDJMonitoring to always)
geposted Tue 04 Apr 23 @ 9:18 am
I am looking for a script that will toggle between 2 and 4 decks.
I have tried switch_skin_variation' and '@4$deck20' and skin_panel'@$4decks20' with no luck. Thanks in advance.
geposted Tue 11 Apr 23 @ 2:03 am
On my Skin all Panels get stearing by variables. Inside the "Controller 2020 by DennYo.zip" is a list with all variables and their functions.
For switch between 2 & 4 Deck you need 2 Variables.
The fist ist the number of Decks Variable and the second is the Skin Varaiation.
The Script is:
check "is 4 Deck" ? "set 2 deck & set the variation & load_skin" : "set 4 deck & set the variation & load_skin"
example:
var_equal '@$4decks20' 1 ? set '@$4decks20' 0 & set '@$variation20' 0 & load_skin : set '@$4decks20' 1 & set '@$variation20' 3 & load_skin
The Script is:
example:
'@$4decks20' 0 -> 2 Deck Skin
'@$4decks20' 1 -> 4 Deck Skin
'@$variation20' 0 -> BIG layout
'@$variation20' 1 -> MIDDLE layout
'@$variation20' 2 -> SMALL layout
'@$variation20' 3 -> two BIG + 2 SMALL layout swap (only 4 Deck)
'@$variation20' 4 -> two MIDDLE + 2 SMALL layout swap (only 4 Deck)
'@$variation20' 5 -> BIG EXTRA layout (only 2 Deck)
'@$variation20' 6 -> MIDDLE EXTRA layout (only 2 Deck)
'@$variation20' 7 -> BIG - split layout (only 4 Deck)
'@$variation20' 8 -> two BIG + 2 SMALL layout swap move (only 4 Deck)
'@$variation20' 9 -> two MIDDLE + 2 SMALL layout swap move (only 4 Deck)
'@$variation20' 10 -> 4 Deck vertical (only 4 Deck)
'@$variation20' 11 -> 4 Deck vertical small (only 4 Deck)
'@$variation20' 12 -> 2 Deck simple Video (only 2 Deck)
'@$variation20' 13 -> 2 Deck prepare (only 2 Deck)
'@$variation20' 14 -> 1 Deck prepare (only 2 Deck)
'@$variation20' 15 -> simple Audio
'@$variation20' 16 -> 4 Deck vertical small special (only 4 Deck)
geposted Tue 11 Apr 23 @ 5:18 am
Perfect, thankyou!
geposted Tue 11 Apr 23 @ 7:15 am
Version 3.4.1 - 2023/04/17
bugfix - position bug Support Page on MAC
geposted Mon 17 Apr 23 @ 1:59 pm
Wie komme ich jetzt wieder aus der Nummer raus ???
Ich meine damit, das ich folgendes Bild auf meinem Monitor habe
und nix mehr machen kann. Wie komme ich jetzt wieder zurück zu dem normalen Bild von VDJ.
Bin zu Hause am PC und habe keinen Controller angeschlossen.
Was mach ich jetzt ????
geposted Sat 29 Apr 23 @ 5:08 pm
I wrote the awnser in the german Forum at your post.
You can also find the awnser on this Topic. Go one Page back.
https://virtualdj.com/forums/170146/German_Forum/Neue_Skins_by_DennYo__).html?page=52
geposted Sat 29 Apr 23 @ 5:18 pm
Hi Dennyo. Great work as always!
I think I found a bug in v 3.4.1 :
With browser zoom link active it randomly jumps to browser zoom when you press a folder (for example:
sideview folder shortcuts, selecting folders from pads etc.)
with browser zoom link off it behaves normally. Please try to reproduce.
geposted Mon 01 May 23 @ 8:28 pm
i know what you mean, but this is not a thing from me. A other dude from germany wrote me the same. I self don´t use the "browser link". I don't know if this behavior is new or has always been like this. When it's new, something subtly changed from the browser_isactive verb
geposted Tue 02 May 23 @ 3:20 pm
Ah okay so you mean you can not fix it? Thanks anyway for replying.
geposted Wed 03 May 23 @ 10:09 am
Discussion about Controller 2020 by DennYo
great skin but the lastest update will not recognise my jog picture it worked ok before any suggestions please
geposted Tue 16 May 23 @ 7:31 am
Look inside the Skin.zip.
The img.png has changed.
You must edit the new img.png.
geposted Tue 16 May 23 @ 6:11 pm
since your last update it will not put my logo on the jog wheel worked ok before any solution please
geposted Wed 31 May 23 @ 8:11 am
i have done this but with the latest update it will not show my logo as befroe??????
I add for the next update an function to add your own "on jog logo". I add an area in the img.png. I think the update will upload on the weekend.
show here:
wwwimmjcom wrote :
First, love all the version you have made! Thank you for all the great work! Question, I was able to add my logo to the jog wheel on most skins including HD by DennYo. Have not been able to add it on the stock 2020 skins or the Controller 2020 skin. Is this something with the new VDJ 2020 that makes the jog wheels area un-editable?
show here:
geposted Wed 31 May 23 @ 8:13 am
Version 3.4.1
The Logo works...
I do not understand your problem
The Logo works...
geposted Wed 31 May 23 @ 11:10 am
