stlvs wrote :
I'm not sure that the Browser mouse auto zoom is working in 3.1.1 version
On my sytem it works. You must activate BrowserAutoZoom in the Virtual DJ settings.
geposted Wed 10 Jun 20 @ 1:33 pm
Of course I did that,but it's not working..with the default skin works fine..it is not a big deal for me,i just wanted to let you know as a feedback
geposted Wed 10 Jun 20 @ 4:58 pm
          At the moment there i a bug with update the skin.
For use the newest version you must reinstall my skin.
1.
2.
3.
1.
2.
3.
       geposted Fri 12 Jun 20 @ 8:32 am
          no blue line going around deck 1 like the yellow one on deck 2
       geposted Sun 14 Jun 20 @ 7:44 pm
It work fine Here on Windows 10 PRO, Are you using Mac?
       geposted Sun 14 Jun 20 @ 9:40 pm
The border show the Master Deck or the select Deck.
       geposted Tue 16 Jun 20 @ 10:38 am
          Hello,
First of all thank you for this great skin, it is very complete!
Good job, keep it up!
I have crashes when I load some MP3 files with this skin, even after re-downloading the file and re-scanning it.
The problem doesn't happen on the default skin...
I wouldn't say too much about where it comes from :/ (I just know that some people have problems loading files, an update was released today but it doesn't fix the problem even on earlier versions of VDJ and its crash)
geposted Thu 18 Jun 20 @ 3:41 am
          Again, HUUUUUGE Thanks to DennYo for his amazing skin, my favorite since many years, now.
2 suggestions of idea... or maybe it already exists ?
1 - Save the skin.
Is it possible to save the skin, or add the feature in a next update ?
I customized many of the skin option to fit with my needs and preferences, but if I switch to the VDJ default skin, then back to Controller 2020 skin, I have to redo all the customization.
I use my Infinity License on 3 computers, and copy my settings (in My Docs\VirtualDJ folder). Using a save file to apply my preferences would be really great.
2 - VDJ 2021 and the new features
I know VDJ 2021 has just been released. Will there be an update to implement the Real-Time Stem Separation feature to the skin ?
One more time : many thanks for your work !!
1 - Save the skin.
geposted Fri 19 Jun 20 @ 10:31 am
          The new EQ features do work on old skins. Just add a custom button assigned to eq_mode (which will display the big window with the EQ choices).
The names under the knobs won't change, but the knobs do control the different stem parts.
geposted Fri 19 Jun 20 @ 10:42 am
          great
    geposted Fri 19 Jun 20 @ 10:51 am
          you can convert fixed text under the knob "FILTER" "GAIN" "LOW" "MID" "HIGH"  to corresponding actions "filter_label" "gain_label" "low_label" "mid_label" "high_label"
          I bring an update on this weekend with the new EQ Funktion.
    geposted Fri 19 Jun 20 @ 10:55 am
Thank you very much! Great Job!!!
geposted Fri 19 Jun 20 @ 11:37 am
Can someone please script: eq_mode to cycle through the Advanced EQ Mode on a custom button?
geposted Fri 19 Jun 20 @ 12:32 pm
          to open the eq control page : eq_mode
toggle mode and back : eq_mode +1
geposted Fri 19 Jun 20 @ 12:54 pm
          FYI
eq_mode +1 is actually assigned to the text under each knob on the default skin.
Trying it though, it only seems to switch between the first and third options.
geposted Fri 19 Jun 20 @ 1:00 pm
          eq_mode +1 will switch between normal frequencies (high/mid/low) and which ever new setting you have selected (EZRemix/ModernEQ etc).
    geposted Fri 19 Jun 20 @ 1:04 pm
          More like stem_mode on/off then :-)
Oh OK so no way of cycling?
geposted Fri 19 Jun 20 @ 1:06 pm
setting 'eqmode' 'frequency' ? setting 'eqmode' 'EzRemix' : setting 'eqmode' 'EzRemix' ? setting 'eqmode' 'ModernEQ' : setting 'eqmode' 'Frequency'
geposted Fri 19 Jun 20 @ 1:07 pm
          setting 'eqmode' +1
Much easier :-)
    Much easier :-)
geposted Fri 19 Jun 20 @ 1:15 pm
