Forum: Addons
Topic: Controller 2020 by DennYo - Page: 9
NicotuxHome userMember since 2014
for me setting 'eqMode' +1 does not work at all
eq_mode +1 working as Dan said (normal/selected)
geposted Fri 19 Jun 20 @ 2:18 pm
stlvsPRO InfinityMember since 2018
Dan (djtouchdan) wrote :
setting 'eqmode' 'frequency' ? setting 'eqmode' 'EzRemix' : setting 'eqmode' 'EzRemix'  ? setting 'eqmode' 'ModernEQ' : setting 'eqmode' 'Frequency'
Maybe you could include and the 4th option "Stems" in your script? Thank you very much!!!
geposted Fri 19 Jun 20 @ 3:45 pm
setting 'eqmode' 'frequency' ? setting 'eqmode' 'EzRemix' : setting 'eqmode' 'EzRemix'  ? setting 'eqmode' 'ModernEQ' : setting 'eqmode' 'ModernEQ'  ? setting 'eqmode' 'Stems'  : setting 'eqmode' 'Frequency'
geposted Fri 19 Jun 20 @ 3:57 pm
Excellent! Thank so much!
geposted Fri 19 Jun 20 @ 4:34 pm
Love your skins!
I just upgraded to VDJ 2021. In 2020 I could set my wave form to multi-colors. (not just Red & Blue) Is this not possible with VDJ 2021? If so, What am I missing?
Thank you,
Olyn
geposted Fri 19 Jun 20 @ 10:32 pm
AsTheDJPRO InfinityMember since 2008
Denny DennYo wrote :
AsTheDJ wrote :
no blue line going around deck 1 like the yellow one on deck 2
The border show the Master Deck or the select Deck.
the ring around the deck not the line ( Master deck )
geposted Fri 19 Jun 20 @ 11:43 pm
lincol2PRO InfinityMember since 2011
Thank you Guys
geposted Sat 20 Jun 20 @ 2:22 am
I can not reproduce the BUG. Can you please post a screenshot of the "Variable support page". (skin button/Variable Support)
geposted Sat 20 Jun 20 @ 7:25 am
A small help please! How can I resize text ONLY in this area?? Thank you!!
geposted Sat 20 Jun 20 @ 2:24 pm
Will this skin work with new features of 2021?
geposted Sun 21 Jun 20 @ 11:11 pm
Why not just try it and see ? Its really that easy
geposted Mon 22 Jun 20 @ 12:43 am
Version History 3.1.2 - 2020/06/22
-add - the new stems feature
-add - toggle the HOTCUES to saved Loops ("Skin Button"/Deck Setup/HotCUEs/SaveLoops)
geposted Mon 22 Jun 20 @ 5:17 am
open the skin.xml an search "---topzone---"
in the bottom of this are all topzone buttons.
You can change the size by using a other textzone class.
For example:
<textzone class="text11" x="1482" y="10" width="25" height="15" align="right" text="VOL"/>
change to
<textzone class="text12" x="1482" y="10" width="25" height="15" align="right" text="VOL"/>
for a bigger font
or change to
<textzone class="text10" x="1482" y="10" width="25" height="15" align="right" text="VOL"/>
for an smaller fontsize.
Not all font sizes are available as class.
You can change to.
text8
text9
text10
text12
text17
geposted Mon 22 Jun 20 @ 7:24 am
[quote=stlvs]A small help please! How can I resize text ONLY in this area?? Thank you!!
Thank you very much Denny!!!
geposted Mon 22 Jun 20 @ 4:59 pm
When will this version be released? I don't have it as an update yet. :)
geposted Tue 23 Jun 20 @ 9:04 pm
We must wait for check. I have it uploaded on monday.
geposted Tue 23 Jun 20 @ 9:30 pm
[/quote]
Awesome!!!!!
geposted Tue 23 Jun 20 @ 9:42 pm
First off, I want to thank you for having overall in my opinion the best VDJ Skin.
I have a question is it possible for you to have a minimized version of the skin?
For example , to remove the loops,poi,lock,snap, rec,save & load on each deck
In my opinion that area is crammed, hard to see while DJing, & makes the skin looks crowded.
Thanks for your time & regardless i will continue to use your skin
geposted Mon 29 Jun 20 @ 4:11 am
Good Skin.
But I miss the Option to Change the ColorFX ;-)
geposted Mon 29 Jun 20 @ 12:44 pm
You can change colorfx - with the button next to the filter knob.
geposted Mon 29 Jun 20 @ 12:49 pm
36%
