Discussion about Denon DJ Prime 4 Screen
geposted Mon 27 Apr 20 @ 8:47 pm
When trying the connect virtual DJ 2021 to my prime 4, the prime 4 screen does not work (it just has a black screen that says computer mode). The virtual DJ logo is showing on the jog wheels but not the screen. How do i get virtual DJ to properly connect to the prime 4 so i can use the screen?
geposted Wed 19 Aug 20 @ 11:04 am
Is this the first time you've set this up, or were you using the previous mapping etc?
geposted Wed 19 Aug 20 @ 12:08 pm
Can you check in Documents\VirtualDJ\Plugins64 if akairemotescreenlib is there, and in Documents\VirtualDJ\Skins if the Denon Prime 4 skin is there?
geposted Wed 19 Aug 20 @ 1:17 pm
It works super greatly but sometimes shows an incorrect BPM in the screen. for example: the song's bpm is 96 (in the PC's display) but in the Prime 4's display it's 95 and this happens pretty frequently. Any solutions?
geposted Wed 19 Aug 20 @ 7:55 pm
Which skin are you using on the computer?
geposted Wed 19 Aug 20 @ 8:10 pm
I use Project X from Dan.
geposted Wed 19 Aug 20 @ 8:14 pm
I've changed the skin to default but I'm still having the same BPM issue. Here's a video:
geposted Thu 20 Aug 20 @ 2:55 pm
