steph972, unfortunately  Denon SDK is not compatible with 10.13. You will have to upgrade your Mac  to 10.14 or higher to have the Prime screen working
    geposted Sun 22 Nov 20 @ 11:32 am
          Ok merci
    geposted Sun 22 Nov 20 @ 12:10 pm
pwaudios wrote :
When trying the connect virtual DJ 2021 to my prime 4, the prime 4 screen does not work (it just has a black screen that says computer mode). The virtual DJ logo is showing on the jog wheels but not the screen. How do i get virtual DJ to properly connect to the prime 4 so i can use the screen?
Hello, I have a new Prime 4 and have the same issue. Can someone help me?
geposted Fri 12 Mar 21 @ 5:16 pm
          DENON DJ PRIME 4 SCREEN no access to denon engine lighting
    geposted Mon 13 Dec 21 @ 2:34 pm
So from the sound of it nobody has an answer to fix this? I am all up to date on everything. I have tried different skins. I have re-download everything. I meet and exceed system requirements. Anybody get a fix for this yet?
geposted Wed 20 Apr 22 @ 6:43 am
          Try to install this .. https://aka.ms/vs/16/release/vc_redist.x64.exe
and then open VirtualDJ again
geposted Wed 20 Apr 22 @ 12:21 pm
          Still no change after that download unfortunately.
    geposted Wed 20 Apr 22 @ 6:34 pm
          Problema... Virtual dj ultimo aggiornamento...insieme a  denon prime 4 ...su 4 ore di DJset è capitato che la traccie si sono frizzate cinque volte... È la terza volta che esco con questo nuovo binomio ed è la prima volta che si manifesta... È capitato anche a voi?
    geposted Wed 29 Jun 22 @ 5:06 pm
