Forum: Addons
Topic: Project X - Page: 2
I will not add any custom more buttons, I will not add any more custom buttons, I will not........ [OH]
Now has 88 if you split left/right decks
That's a brilliant addition Dan, especially for DMX control when there are so many different scenarios.
Mind you, I've not seen my moving heads since March, think they're in the garage somewhere with the rest of my DJ gear .....
1.0.2
  • Option for browser to maintain grayscale theme when changing main skin theme (Menu -> Browser)
  • Brighter Pitch Lines
  • Option for custom buttons in top menu bar (Menu -> Menu Bar)
  • New lighter theme (between daylight and default) replaces black theme
  • Fix mid eq not resetting on dblclick
  • New custom button rack option
  • Additional Loop panel to enable more options from a single view (slots etc)
  • Option to display EQ kill buttons (not currently available in Broadcaster or Pro when 5 knob stems enabled due to space constraints - but you can right click on the knob to kill it)
My Prime 4 hasn't left my side since it arrived.
When I go back to work next month, there may be withdrawal symptoms... :-)
Just use a custom button. LOL!
@Dan - how about Pioneer waveform colours?
Next Build:
Also fixes shape colors not being remembered between skin variants.
oh Dan, what have you gone n done?, are you the one to finally wean me off the Legendary FRUiT skin?....., I think a thorough testing is needed, but so far so good, and with all those custom buttons I can finally add almost every one of the bonkers locodog scripts
Not bonkers!
UFO scripts 🤣🤣🤣 You won't even need testing. Just open the xml and check the coding there! Its so neat compared to FRUiTs coding! This should be the new default skin! Can't say it enough times!
I have done 5 gigs with this skin and it was almost perfect. And then you added MORE BUTTONS and made it perfect. Thank you!
( I see a scene in my mind with "(Don't Fear) The Reaper" cranked to the max and Christopher Walken is leaning over your shoulder saying "More buttons" )
When will the Performance layout be coming? I can hardly wait. (If you need a beta tester... hint hint... just saying... )
Hey Dan, It would be great if you could remove the shadows on the waves ?
I want the beats to be shown as much as possible;)
Is it me, or am i missing something?
There doesn't seem to be the play/pause feature button on the decks?
On my skin, there is just cue / play / sync
Thank you
I believe that one of the buttons in the extended button panel is mapped incorrectly at least when split custom buttons are used. It is in the group of 6 buttons on the right side. Lower left button.
This button responds to a correspondingly programmed button on the left regardless of what button is used on the left side.
Thanks
You don't see the pause graphic on the centre button? Check in VDJ config that you have playMode set to play-pause.
Next build the left side buttons will respond to the left deck and the right side to the right deck.
The centre buttons will remain deck independent.
I'm working on it. But no ETA just yet.
Thanks Dan!!
Is there a way to make the font on the decks and in the buttons brighter?
Will look at possibly adding an option for this. But I'm going to get performance view done first.
Sweet!! Thanks!
Performance Mode - coming soon!!
2 Decks, no waveform
2 Decks, default waveform (waveform can be enlarged and moved to the middle the same as the other skin variants)
2 Decks and +2 Deck Rack activated
2 Decks and all racks activated (+2 Decks, Mixer & Video)
Waveform in middle
Only video deck active - all racks can be independently turned on and off for ultimate customisation
That's great Dan! Big thanks
25%
