Forum: Addons
Topic: Project X - Page: 3
1.1.0 (12-07-2020)
  • NEW Performance Layout Added
  • NEW Option for bright text (Menu -> Colors -> Brighter Text) (not available in Daylight & Lighter themes)
  • NEW Pioneer Themed Shape Colors (Menu -> Waveform -> Colors -> Shape Colors)
  • Custom Buttons in Custom Button Rack now respect Decks
  • FIX check marks for the selected skin when using a skin edit
  • FIX song wave position displaying incorrectly in deck 3 & 4
  • FIX time remaining/elapsed in platters sometimes cut off on smaller screens
  • Pads now updated to work with new build (6011) - Old functionality maintained for earlier builds
  • Higher contrast to knobs and buttons
Congrats. Great beautiful looking skin, Job well done. With that being said the Browser's Folders/Sideview/Info's Lettering are too Small hard to read compare to DJDaD's Blocks or PhantomDJ's Vectro perhaps is the choice of Fonts. keep up the hard work you're doing it's Appreciated...Thanks.!!! (No Preview.png?)
Renaming cue points is already there. But you must be in a hot cue view. You can't do it on the pads.
[EDIT] so you changed your question? To one about font sizes in the browsers tabs. I'll review, but no plans currently to change this.
Great skin! Been using Fruit for years, but think it's time to make a change.
I'm know it's not possible with current functionality, however any way to make a song in the browser have the strikethrough font for played tracks? Similar to the existing icon, but for the track details in the broswer.
Thanks!
Waits patiently for Performance Mode update to migrate to my machine...
Check in extensions - update should be available now.
It's available - it just doesn't show on the extensions page because of the damn caching. Just uninstall and reinstall.
Won't deleting the current install also delete my custom buttons?
No it won’t delete the button definitions.
Awesome!! Thanks Dan!! Great looking job!!
OH, BTW, when I discovered the Performance build was available I was about to report that when you have the Green/Orange Deck Colour selected that the color of the wave forms are reversed. Orange wave form in the Deck 1 and Green in Deck 2
I don't wanna be any pain for you Dan, but I have some more suggestions.
The best way to show you is with pictures, so here it comes (to bad that we cant send pictures over messages here on the site :(
1 - There is no room to expand the custom buttons along the top line - you may think there is but there isn't
2 - The things you've highlighted in the top picture regarding brighter text aren't text, so they won't get brighter. But will review to see if I can change.
3 - There is no way to change the column header text (at least not that I know of). It will however change size with the browser font increase buttons.
4 - I will look to see if I can add an option for the deck info panel to be 100% black. (I like it being semi transparent though)
5 - What eq mode are you using to not see the eq_kill buttons (or have you disabled the mathEngine)?
6 - Brighter text (2nd picture) in the scratch view will be fixed next build.
DJ Riot Grrrl wrote :
/OH, BTW, when I discovered the Performance build was available I was about to report that when you have the Green/Orange Deck Colour selected that the color of the wave forms are reversed. Orange wave form in the Deck 1 and Green in Deck 2
Good spot - fixed in next build
In next build faders and all icons will also respect the brighter text option.
Additional option for black info panels in next build.
Wanted to refresh this question, thanks
It's not possible. You can define fonts in the browser, but not a font for played tracks.
It's disappointing that Atomix have not given us this option (e.g. showing played tracks in a different colour) despite many requests.
The tabs can be made larger though...
Lol thanks groovin
FINALLY!! The ULTIMATE VDJ skin. I LOVE IT. Thank you!
38%
