Forum: Addons
Topic: Project X - Page: 4
Any chance of getting the custom button rack on the performance mode
geposted Sun 19 Jul 20 @ 1:37 am
I'll look at. The problem is the racks work differently in the performance mode to the others. As you can select all 3 of the currently available racks at the same time.
Where as you can only select 1 rack in the Pro.
That said I'm almost finished on a variant of Project X, called Project X Slider. Which has 2 rack in every view (Pro, Performance and 4 Deck).
Custom buttons is an option here.
geposted Sun 19 Jul 20 @ 1:43 am
Will that be within the current skin as a drop down option or a new skin?
geposted Sun 19 Jul 20 @ 10:37 am
It’ll be a new skin as some of the elements work completely differently.
geposted Sun 19 Jul 20 @ 11:00 am
Dan, I noticed that the BPM is shown in shown in the platter and in the song information, maybe this is something that could be added to the platter as a custom field so you could say add, year, label and comments.. just a thought. Thanks again
geposted Sun 19 Jul 20 @ 12:29 pm
I’ve added it to my list to see what I can do.
geposted Sun 19 Jul 20 @ 12:30 pm
1.1.1 (19-07-2020) -
  • NEW Option to show loaded track year, label and comment in Broadcast View
  • NEW Option to show loaded track year in Pro and Scratch view
  • Other minor fixes/tweaks
main menu > decks >
geposted Sun 19 Jul 20 @ 1:22 pm
Thanks Dan for the Skin.
Been playing around with this (I like lots of custom buttons) and trying to change the Deck Platter to Display your own with no success.
Can we change that to are own logo ?
geposted Sun 19 Jul 20 @ 5:01 pm
Which skin variant are you using?
Pro allows custom platter but you’ll need to edit to PNG file. When you open the PNG you’ll see the platters in the lower right.
geposted Sun 19 Jul 20 @ 5:03 pm
I was editing this....
NOW I see when you mentioned lower right.
Thanks
edit
I tried changing this
it's not displaying for me.
I am using the PRO skin.
Figured it out (I assume when I chage it, it will show, I have to click on the CONSOLE view to enable it there.
Thanks.
geposted Sun 19 Jul 20 @ 6:53 pm
Glad you figured it.
geposted Sun 19 Jul 20 @ 7:22 pm
Trying to figured out to show LOGO when deck is empty (nothing loaded) instead of just BLACK.
Could you point me to which one to change.
I tried the 2 BIG circle from the LEFT side (above pic).
Thanks
geposted Sun 19 Jul 20 @ 7:28 pm
That’ll need you to edit the XML. I’m out at the moment, but will be home soon.
I’ll look then and let you know.
geposted Sun 19 Jul 20 @ 7:30 pm
You need to find these lines of code. You can see the line numbers in the screen shot also. Just removed the visibility="loaded".
geposted Sun 19 Jul 20 @ 9:12 pm
Thank you so much Dan.
geposted Sun 19 Jul 20 @ 10:09 pm
freppaPRO InfinityMember since 2002
Thanks Dan, its the first choice for me now
geposted Mon 20 Jul 20 @ 9:34 pm
That’s great. I notice you still don’t have kill buttons.
By any chance are you using the 32bit version?
geposted Mon 20 Jul 20 @ 10:09 pm
yes still going with 32 bit version, the reason is some vsts, Telly and milkdrop ;)
geposted Tue 21 Jul 20 @ 6:05 am
That will be why. Will add a fix for the next build.
geposted Tue 21 Jul 20 @ 8:52 am
@Dan> Great job, thanks for that !!
And when do you build the conntroller that can operate all of this? lol
geposted Tue 21 Jul 20 @ 12:11 pm
58%
