Forum: Addons
Topic: Vocal FX
geposted Sat 20 Mar 21 @ 10:18 am
Hey, I like this effect, what can i do to turn on the effect when I press the button just once. Deactivate it by pressing it again, Same for light, Turn it on the button light when pressing the button and turn it off when deactivating the effect. Than you.
Also, after I use the effects Echo, I wont be able to use the normal echo effect,
Hi there, did you find a solution to your enquiry? I am also interested in figuring out how to toggle the effect on and off with LED feedback as well.
Is there a way to change it to toggle On/Off?
It's a padpage all the script is available there to read and adapt.
