Forum: Addons
Topic: Prime 4 Modified Screen - Page: 1
geposted Tue 08 Mar 22 @ 3:57 am
 Best Answer In your Skins folder, you will see the default Denon Prime 4 Screen Skin.zip file. You will need to delete it and then rename the one was downloaded there with the same name as the default one.
If you wish to go back to the default one, simply delete it and VDJ will automatically download the default on next launch.
[ selected best answer by locoDog on Fri 06 May 22 @ 12:56 pm ]
Won't let me install through the app even though I have Infinity Pro. :-(
The best screen for the Denon Prime 4 💻🔥
Is there any chance to have to have the waveform of all 4 decks shown at once vertically, like it is in the software of the Prime 4?
I am not seeing this in my skins ? Am i missing something?
You won't see it in your skins (the list of skins in VDJ) because it's a Prime 4 skin.
 Selected as best answer
Thank you DjDAD
Think maybe that should be written in the description of the extension.
I hope so, in near future. Still working on it.
you have to rename downloaded file Denon Prime4 Screen.zip exact
Thank you DjDAD
I can upload only zip file
This is THE BEST SCREEN for Prime 4 ever ! Tnx man you are the one!
Tomas Cerny (VeeJay Lizard) wrote :
Discussion about Prime 4 Modified Screen
How are you my friend, its the best skin for prime 4 that i seen all my live.
i installed on my prime 4 and everthing good, see the video on the prime screen is crazyyyyyyy i love it.
the only thing is, im having a lot of delays btw my laptop and the controller.
its sometimes about 2 and 8 seconds. that happend to you any time? any solution?
i restarted my laptop after do all the process just to let you know.
by the way any group on facebook, ws to get updated or more info about all your work?
I only have a small video window on my left side of the screen. Am I doing something wrong or is there a way to get full video screen like I’ve seen on YouTube. I’ve repeated the process a few times even after I deleted the default copy. I hope it’s there when I turn it on this time. Thank You for the new look.
My screen looks like yours with a small video screen but the buttons on top are blank. I’ve tried to reboot by re downloading the file. Any suggestions???? Thank u brothers
@Supetown
This usually happens when files (Denon Prime4 screen.xml and Denon Prime4 Screen.png) are not zipped.
@Djewingm
Large video was removed. Try change your screen fps to 30 in VDJ settings
I had on vdj skinFPS (60) I just changed it to 30.
I'll test it tomorrow all night playing at my work place, really thanks.
Any YouTube channel?
Any group on facebook?
Any group on Whatsapp?
My looked the same. Blank bottoms. But when I rebooted it a few times the buttons are there now. Still I only get the same look u have. A small screen. It may take you several times of downloading it and delete if the default version. I had to do it at least 5 times. BUT it has worked on my last 4 gigs and I work 3 times a week every week. I did see a guy on YouTube get the full screen to be a video! I tried to watch the video over and over and I also speak Spanish. (His video is in Spanish) but the guy talks fast as hell and he never fully explains the full screen look only the download process. Good luck brother
I mean to say blank buttons
@Supetown
As stated earlier, full screen video was included in earlier versions of my skin, but was removed as this was not working well due the refresh rate of Prime 4 screen.
Regards Tomas.
31%
