Forum: Addons
Topic: Prime 4 Modified Screen - Page: 2
Oh ok thank for helping me out on that. And thank for the skin. Sure is a nice look and helpful. Best of luck through the year!
Hello, with this skin can i zoom out the entire waveform on the prime 4 screen? Or only a few bars as a standalone mode? Thankss
Hi ! . I am using your screen since I find it and I think it is great but Is there a way to add VU meters ?. .
Thank you !
Thank you !
What it will be good for? You have them on controller.
Sure you can
Moderator: Type in English please.
Hola como puedo obtener este skin para el prime 2 con los mismos colores de guía de onda de la imagen.
Hello, how can I get this skin for the prime 2 with the same waveguide colors as the image.
The waveform colors on the default Prime 2 Screen skin can be changed from the Settings (hold down the VIEW button on the Prime 2 for 2 secs) in the WAVES tab
thanks, very useful help 👍🏼
hi does it work on prime go?
@Tomas. Thank you so much for creating this modified Prime 4 Screen Skin! I noticed from the picture in this thread and on YouTube videos that you updated it to have 3 screens (player 1, 2, and the main video output) but when I load the new updated skin dated Jan 4 2023 it still has only 1 main video output screen on the left side of Prime 4 screen. Is there a way to get your newly updated skin with the 3 screens?
I don't know if this is default behaviour, but on the Prime 4 screen, putting a finger on the video player screen and swiping right then displays all three screens as per the videos on YouTube :)
Should be like that. Second tap will switch it back.
Thank you for clarifying how to get the 3 screens for video!
Hello,
i have a huge delay between vdj and prime 4 how can i fix this problem
Skin Developer: I hope you get a commission, because your skin just earned a virtual dj sale... Nice work :)
do you have delay between vdj and prime 4 ?
I've been doing some minor changes on the skin to fit my needs...
Now I wanted to change the color of the selected track bar, in file/folderlist so it stands out a bit more from the background grid on the P4 screen.
But cant seem to find the right line in the skin xml to edit with new color code... can you help me out here ?
Looking for some assistance as I'm missing something crucial I'm sure. I was able to get the Prime 4 Modified skin loaded however I have blank custom buttons at the top so I'm guessing A) I can populate or B) I'm missing something. Also I play a lot of videos and I don't have that button on my screen? Any help is appreciated.
Thanks.
Dris
@DRISK101 can you please upload picture what do you see. Video button is viewable only if two deck horizontal screen is selected. Custom button can be mappable by yourself. Best way to do that in default VDJ skin on your PC or Mac.
Regards Tomas.
63%
