Forum: Addons
Topic: Prime 4 Modified Screen - Page: 3
HI, will this skin work properly with a prime 2.
With some limitations, and need to be reworked a bit.
Hello, i.ve a Prime 4+, using this modified screen skin gives me a black screen unfortunately. Engine OS is version 3.2.0. Anyone else has this problem, or some knows howto fix this?
Tnx
Tnx
I have the same problem. I bought Prime 4+ today. The Atomix version works, but this version from Tomas doesn't.
I have the same problem I have a Prime 4+ with version 3.3.0 The Atomix version works, but this one doesn't
Same issue here. Prime 4 just give a black screen. Default one works fine. @Thomas can you perhaps assist?
Follow the instructions given earlier in the thread.
Renaming no longer works.
How do we install this??
@Tommas,
Seems there is a bug in the skin xml
Line 3334 ..
<panel name="horizwaves" visibility="var '@$prime4horwaves' 1 ">
The variable starts with 0, so the entire panel is not visible, black screen.
Since it seems that you dont offer vertical waves view, better remove the visibility completely
@DJDAD will changing the value to 1 make this skin work again?
Already did that, Denon screen is just black
Screen on Denon is just black after following all the steps. What can we do in this case?
Please read the thread! The skin has an error in the XML code.
Uploaded fixed skin file. It is just pending review. Thanks for reporting this bug.
Regards Tomas.
@DJDAD Thanks for pointing me to right line, totally missed that
HENRY JAY wrote :
Tomas Cerny (VeeJay Lizard) wrote :
Discussion about Prime 4 Modified Screen
Look at the artwork in action!
Love it
Tomáš díky za skvelú prácu! Vďaka Tebe som nepredal Prime 4+!!!
Dej mi na sebe kontakt, pokud budeš potřebovat něco upravit na skinu, tak dej vědět.
Ahoj, mám otázku. Ako sa zapínajú 3 obrazovky ako to je na screene? (kontakty máš v správe)
(Hi, I have a question. How do you turn on 3 screens like in the screenshot?)
94%
