YEAH, finally :D I might have been a bad searcher for the last years or missed something, but milkdrop 64 bit plugin runs soooo smooth, I feel its 2-3x framerate count as the 32 bit version.
https://forum.sbdj.co.uk/viewforum.php?f=15
Here are the plugin, I had to copy the files after installing from My Documents/VirtualDJ to c:/Users/My user/appdata/local/VirtualDJ to make it work in 64bit VirtualDJ. And with the preset pack https://sourceforge.net/projects/mdpresetpack/files/mdpresets.zip/download
with over 50.000 presets you'll have new presets all the time. Nice :D
Thanks SBDJ :)
Edit: I also have an old gfx-card (AMD Radeon R7 200 Series), running 1920x1080 with all settings on max, and get 60fps without a glitch now. I have a projector so my whole living room is lighting up with milkdrop effects :D
Thanks SBDJ :)
geposted Thu 02 Feb 23 @ 7:43 pm
I cant wait to get my new rig up and running, with GeForce GTX 1080 FTW 8GB GDDR5X gfx card and Intel Core i7-9700F 3.0GHz (Turbo 4.7GHz) 8-Core on a MSI Z390 motherboard. I need a 4k 144fps projector, thats for sure. :P
geposted Thu 02 Feb 23 @ 7:56 pm
@SBDJ
i been using your plugin for a while no issues recently it stopped working.. i had uninstalled it re installed etc. it will not go in the virtual dj video output screen.. but it pops up on its own screen if you click Engine... is there a file i need to edit to force it to work again... i have tried copying from my other computer that it works fine on.. but my main dj rig.. it will not push the video out the video output just the engine output a seperate screen.. is there a reason it stopped working?
geposted Tue 10 Sep 24 @ 10:39 pm
If the "Engine" fx button is turned off, it gets properly displayed on the VDJ Video Output here.
You have all the files in VDJHomeFolder\Plugins64\Milkdrop2 folder and milkdrop.dll in VDJHomeFolder\Plugins64\Visualisations folder ?
VDJHomeFolder might be in /Documents or AppData/ folder, so find it from the small cog-icon in OPTIONS tab https://virtualdj.com/img/370573/29893/Options.png
geposted Wed 11 Sep 24 @ 10:04 am
@DJDAD
ya when i re install the program i take it from the Documents Folder and it place it down in the new location Virtual DJ installs too now..
when i enable the Milkdrop or have it set in settings use milk drop as audio files only.. all i get is a black screen through the virtual dj output screen.. other visuals will work.. but milkdrop wont.. but if you click the engine it props up its own display and that works.. and beats to the music but it wont push it through the visuals..
ive tried copying the folders from my working other dj computer same folder placed it in the same folder... and still black screeen through the output of vdj... i figured maybe drivers.. i updated my nvidia drivers and all windows updates still doesnt.. i also installed directX but all i get is black screen
geposted Wed 11 Sep 24 @ 12:54 pm
I had the asme problem.
You have to use the 3.0.0.0 installer first that one seems to set the milkdrop output to the VDJ screen .Then install the new 3.0.1 for updates and final fixes from SBDJ. The file is on HIS website.
geposted Thu 17 Oct 24 @ 7:12 pm
Is there a working link out there? The first link in this thread to the forum.sbdj dont exists.
Can someone provide the working files or a link to this 64bit plugin?
Thank you!
Thank you!
geposted Tue 24 Jun 25 @ 3:57 pm
His website and forum are now gone.
Just use shaders instead.
https://virtualdj.com/wiki/shadertoy.html
geposted Tue 24 Jun 25 @ 4:06 pm
Forum's gone, but I left the plugins up.
geposted Thu 10 Jul 25 @ 6:06 pm
geposted Thu 10 Jul 25 @ 6:36 pm
Good to hear from you Scott.
geposted Thu 10 Jul 25 @ 6:57 pm
Hey, hope you guys are all doing OK :)
geposted Sun 27 Jul 25 @ 7:34 pm
Brilliant thanks. How are you and the family?
geposted Sun 27 Jul 25 @ 7:42 pm
Sorry to hear that Scott. Unimaginable loss. Keep looking to the future, time is a great healer.
geposted Thu 31 Jul 25 @ 10:17 am
Revisiting this thread in the hopes someone may be able to shed some light on why after finally successfully updating the new VDJ with the latest Milkdrop that while it works, after a few seconds, both the mini display window in VDJ and the external window both start to 'glitch' - like quadrants begin to flash, show skeleton grids, could be 1 bottom right, or 4 or 5 similar to bad ram on a video card but it's not. There's some sort of incompatibility happening somewhere.
VDJ's Shader works fine and Milkdrop on it's own works fine. I've installed DX9 stuff, gone into my vid card NVIDIA settings and turned on Vertical Sync, triple buffering, etc... nothing changes it.
Have to dump it and use the less impressive Shader system unless I can figure out what's wrong... :(
geposted Mon 15 Dec 25 @ 12:23 am
I'll give it a try here and see what happens...
OK I'm not really sure what you mean without seeing a picture, but I ran with Milkdrop enabled for around 10 mins and didn't see any major issues.
I did notice on some of the really stroboscopic presets, there's kind of a black chessboard grid pattern that flashes up - is that what you mean?
It doesn't do it on the presets that don't involve fast flashing.
Disclaimer: I don't use Milkdrop enough to know if this behavious is new.
geposted Mon 15 Dec 25 @ 10:35 am
I have replacement for that old Milkdrop plugin... :)
geposted Tue 16 Dec 25 @ 1:10 am
We're all ears...
geposted Tue 16 Dec 25 @ 11:27 am
Ok - so upon further inspection, it looks like the newer 64bit versions of Milkdrop don't support old milkdrop fx, only some so time to weed them out. This is what happens when encountering a bad fx plugin:
https://youtu.be/zzmz2K33upI
geposted Mon 22 Dec 25 @ 6:06 am
Yeah that looks very similar to what I was seeing, but mine only seemed to be happening on presets that flashed on/off a lot.
geposted Mon 22 Dec 25 @ 10:25 am
