SBDJ wrote :
I have replacement for that old Milkdrop plugin... :)
Is the new replacement on your site ..I can't wait..I new i wasn't bugging as I was trying to delete the ones that glitch. Or turn screen black
O btw.. its good 2 see you active iarounf here
again 😎
geposted Sun 28 Dec 25 @ 1:03 pm
New development:
If you switch on the main video between Shader and Milkdrop. No issues.
However if you choose Dual video mixing and then go from Milkdrop to Shader under the OVERLAYS section, VDJ crashes and restarts....
If you change it under "source for audio only tracks" iit's fine...
geposted Fri 02 Jan 26 @ 6:05 am
I use it under source “audio only “ but it glitches on some and some turn the screen black for a until
next visual mixes in
geposted Fri 02 Jan 26 @ 6:35 pm
Sounds like what I'm getting. Looks like it's almost there - definitely usable. I just need to sit down one day and go through all the many many many many..... presets and make note of the ones I can use.
ALSO! Is there a way to turn off cycling and just get a menu of what's available so you can trigger/select the effect you want sorta like what Shader does?
geposted Sun 04 Jan 26 @ 8:13 am
Ok so in options for milkdrop where it says SD FD FHD etc
SD seems to not glitch i still get some black screens but in ok with that..graphics look soo much better now without the boxing glitches.
geposted Mon 05 Jan 26 @ 8:15 am
Hey i have install the latest milkdrop from the link:
But in VDJ i cant find milkdrop,
can anybody help please?
https://www.sbdj.co.uk/plugins/
geposted Tue 10 Mar 26 @ 3:34 pm
