Forum: Addons
Topic: GTS-2K25 - Page: 3
I think maybe "V8 but by FRUiT" takes the prize for that (it's more than 10 years old now!).
@Blckjck
Bug found and will be fixed on next update. Thanks!
I remember that one. It had a lot in it.
Maybe you guys at VDJ should consider having such a beautiful skin as the "default"
hi I have a Mac 2017 15" I love the skin but it shows up very small. can the decks be expanded?
Thnx for the ( great ) update !!!
Can you pls add an oprion at deck screen info ( at line 3 ) for the musical Key ?
https://files.fm/u/msfdx7b72h
Musical Key is always visible at the dedicated KEY control panel. Is there any specific reason you need to see it twice ?
Also if you click the "KEY" label you can toggle the key display between Camelot and Musical display:
Almost perfect skin!!
Unfortunately, the ActionPads are missing in the Prepare view,
because I use them to quickly create my standard cues/loops, etc. I have a few macros running that save me a lot of work, especially with typical club music.
But great work!
