Kudos to the developers at VDJ regarding the new fluid beatgrid editor. I’ve tested it with a number of difficult tracks and it seems to work quite well.
A couple of comments;
- You should be able to batch process tracks and not be limited to do them one by one.
- Time to actually process a single track seems quite long. Using a competitor’s software, this process is almost instantaneous. So work to do here.
geposted Thu 19 Feb 26 @ 2:19 pm
I believe the devs said the batch processing is coming.
Analysis was virtually instantaneous for me - 1-2 seconds on every song I tried.
geposted Thu 19 Feb 26 @ 2:54 pm
@Herscr1
What are your computer specs ? (Processor, Video Card)
geposted Thu 19 Feb 26 @ 4:32 pm
Quick question, for the fluid beatgrids , do we have to analyze tracks individually?
Or is it done part of the analyzing /song loading process?
geposted Thu 19 Feb 26 @ 5:49 pm
In "OPTIONS" there is "keepBPMonAnalyzerUpdate".
Maybe if this is set to "No", all songs will be analyzed by loading (cause Analyzer has been updateted)?
geposted Thu 19 Feb 26 @ 8:23 pm
In the past, it was very tedious for me to edit a flexible beat grid manually.
That is no longer necessary. GREAT!!!
First of all Thanks a lot for this! VDJ is and will be the best!
Just one option would still be important:
A ‘Shift All Anchor Points’ option.
With a constant beat grid this was & is possible .
I have assigned this to two buttons so that I can quickly intervene if a drum loop is slightly late.
adjust_cbg -1% & adjust_cbg +1%
Unfortunately this don´t work with the fluid beatgrid.
Sometimes even tiny delays in the grid are enough to throw the sync off slightly.
Some drum loops are also slightly behind. A tiny shift could then bring everything back into sync.
Sometimes you have to find a "beat-compromise"...
In the example, some are spot on and others are too early.
Without the Shift function, I now have to laboriously start editing the individual areas again...
So there is only a tiny gap left to absolute happiness.
geposted Thu 19 Feb 26 @ 8:42 pm
With variable grid, it's not possible to move by x ms, as it would throw out all the rest of the grid.
But from what you describe, what you need, is to play with the variableBpmSensitivity setting.
As explained in the other thread, this setting sets the maximum distance (in ms) between an anchor and the actual beat position. You probably want to lower it if you'd rather have very precise anchor position and don't mind many anchors and a fluctuating bpm display.
geposted Thu 19 Feb 26 @ 9:28 pm
Thank You Stephane, but it is intentional to move ALL Anchors.
Sometimes there are more beats off and just a few in time.
In the example only 2 of them are exact but 8 are to early.
(And this is nearly the same in the rest of the song)
So move all the anchors at once will change this to 8 exact and 2 are a bit to late.
That would help me a lot,
and also in general it is good to have a Real-time intervention capability.
It´s about minimal shiftings of all anchors just in case of sudden asynchronity.
geposted Fri 20 Feb 26 @ 7:25 am
ok, added for next build
geposted Fri 20 Feb 26 @ 8:54 am
Great! Thanks a lot!
geposted Fri 20 Feb 26 @ 8:58 am
the only thing i dislike about this, the bpm column shows either the last tempo of the track, or an average of the tempos. I would bet DJs prefer to see the 1st tempo (the beginning) as that's how we'll be mixing it
geposted Wed 10 Jun 26 @ 6:55 pm
Has there been anything introduced for a bulk processing of tracks for fluid BPMs?
geposted Thu 03 Sep 26 @ 1:30 am
I’m also interested in a batch processing for the Fluid Beatgrids.
geposted Fri 11 Sep 26 @ 2:45 pm
Same here
I do a lot of 80s tracks with live drummers and 70s disco with poor clock synths
geposted 7 days ago @ 12:00 pm
It will be nice to edit Fluid Beatgrid like in Rekordbox or Djay Pro.
Right now in VDJ it’s impossible. It’s the main reason I don’t switch from Rekordbox. I play a lot of country music and VDJ can’t offer the correct beat grid for tracks. BTW , in RB and Djay same track have correct beat grids.
Maybe someone will post a tutorial to lighting us.
Regards
Regards
geposted 2 days ago @ 12:31 pm
It's very possible:
https://virtualdj.com/manuals/virtualdj/editors/bpmeditor.html
As a matter of fact, I think the editing is better/more understandable than both platforms you mentioned, especially Rekordbox.
In all cases, I can post a few tracks that none of them get right.
However, at least in VirtualDJ, there are parameters you can use to adjust the process (I think Serato basically copied this in their 5.0 beta too).
geposted 2 days ago @ 12:48 pm
Would a future function be possible to export the "fluid beatgrid corrected" tracks to CDJ's?
geposted 2 days ago @ 1:16 pm
Is that not already possible? Rekordbox has fluid grid capability (to an extent) and other OneLibrary compatible software (Djay Pro) is onboard. Do CDJs not understand their own system yet? 🤷♂️
I don't have modern CDJs so can't test it.
geposted 2 days ago @ 1:21 pm
I asked for this since the Early Access - haven't seen it arrive yet (by this I mean warped tracks).
Exporting the tracks via OneLibrary with a proper Fluid Gruid to match indeed should already be possible.
geposted 2 days ago @ 1:23 pm
Oh he means stabilized tracks. Gotcha.
I don't think Atomix regard this as much of a feature, or are promoting this aspect as much as they could be.
To them it's just a way to keep tracks synced while transitioning. As a start it would be useful to have a lock of some kind, so you could stabilize a track then save the state.
geposted 2 days ago @ 1:29 pm
