| Autor |
- Topic: Console MIDI Output - |
Posted Fri 13 Feb 04 @ 6:17 pm
I am a proud owner of a DJ Console and I am thinking of purchasing the FULL version. I have noticed that you may use a midi keyboard with the full version. Im just a bit stumped on how this would work and what the advantages of this would be. Would you be able to play live while mixing? Any other software required? |
Posted Fri 13 Feb 04 @ 8:51 pm
No, midi support on VDJ is for Midi controler, not to play.
If you have a Midi keyboard (for exemple), the keys could be used as shortcuts. |
