Topic: How can copy Atomix cue database to Virtual DJ?
Dear Sir:
I buy atomix before. Now I saw Virtual Dj is good soft so I want buy it. but I try Virtual DJ I have question, before atomix set many song cue position on Atomix, how can copy to virtual DJ? If can not, I need use many time set cue position to Virtual DJ, It is big problem let me fear buy it, Can you answer me, Thank You.
geposted Sun 08 Jan 06 @ 9:15 am
in the earlier versions of VirtualDJ, i remember, that when you install VirtualDJ, before running the software, if you copy the Atomixmp3 Database in VirtualDJ folder, when running VDJ for the first time it creates a new database using the values from the atomix database.
Therefore, i cannot tell you if this feature still exists or not.
Thanks your answer.
but atomix and Vdj are differnet Cue database format,
copy to folder cannot work.
somebody can help me? I want change to VDJ.
