how do i use my vinyl turntables with virtual dj program?
someone please respond dont just read fourm
geposted Sat 18 Nov 06 @ 10:26 pm
Thats what the forums are here for, you can search for the info you want.
geposted Sat 18 Nov 06 @ 10:36 pm
geposted Sat 18 Nov 06 @ 11:10 pm
thank u skyfxl
so i will need the MAYA44
where can i find that at?
or a sound card with two inputs and outputs?
geposted Sat 18 Nov 06 @ 11:37 pm
try udj45
geposted Sat 18 Nov 06 @ 11:42 pm
whats that like a site or something?
sorry for the dumb question
and i greatly appericate ur help
geposted Sun 19 Nov 06 @ 12:11 am
cant see it sorry
try maya tis similar http://www.audiotrak.net/maya44usb.htm
geposted Sun 19 Nov 06 @ 12:21 am
ok now how do i purchase?
also instead of getting that would 2 sound cards with input output work the same??
i already have one installed i can just install a 2nd one
geposted Sun 19 Nov 06 @ 12:29 am
geposted Sun 19 Nov 06 @ 12:36 am
nice nice...can i just use two sound cards?
geposted Sun 19 Nov 06 @ 12:46 am
i think so but it would put a large strain on your cpu
geposted Sun 19 Nov 06 @ 12:59 am
o..cuz i just maxed out my credit card purchased new pair of turntables and a 2nd sound card is the cheaper way to go
geposted Sun 19 Nov 06 @ 1:10 am
http://www.virtualdj.com/products/hardware.html#djc2
cheaper option :)
mixer plus soundcards:)
cheaper option :)
geposted Sun 19 Nov 06 @ 1:13 am
that link didnt go no where
just to product list
geposted Sun 19 Nov 06 @ 1:21 am
VirtualDJ XP10
is that what u wanted me to look at
mk2 dj console
geposted Sun 19 Nov 06 @ 1:42 am
salut à tous les utilisateurs de VDJ,
j'ai un problème, je ne sais aps cmment cnfigurer l'enregistrement des mix que je fais en 128, ou 192 kbps car il le fait autmatiquement en 56 kbps, alors si vous pouvez m'aider
merci
merci
geposted Mon 20 Nov 06 @ 10:28 am
english please!
ok sorry i have been very busy these past days
so im just using one turntable for virtual dj as of right now..to practice scratching...so what do i need...do i need time coded vinyl?
do i need an adapter?
is there somewhere that i can see how to hook my turntables up to the comp..thank u for ur help
geposted Wed 22 Nov 06 @ 4:29 am
here read this,
this should help u!
http://www.virtualdj.com/products/timecode/
this should help u!
geposted Wed 22 Nov 06 @ 5:58 am
by vdj!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
limited time code vinyl with trial!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
by it if u like it and if u have the money please please please please please please please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
geposted Wed 22 Nov 06 @ 6:05 am
