ok so i still need one of those things that u showed me for two euro dollars....and i need a sound card with some type of stereo input?
my timecoded vinyl is commin in 2morrow i am happy...but still not cuz i cant use for a while
geposted Mon 27 Nov 06 @ 6:15 am
3.5mm 1/8" headphone mini jack splitter Y adapter cable
can i use that instead or no?
just asking
just asking
geposted Mon 27 Nov 06 @ 6:18 am
you need a card like a u46dj
this card has phono inputs
this will proform alot better than y splitters
you can use them if you want but you will need two sound cards with line in
it would be better to use the the one u46dj in my opinon
geposted Mon 27 Nov 06 @ 10:51 am
ok so buy one of those things that has the rca adapter and has the one output thing...and plug that into my sound card "input"
ok how do i set up the config or done mess with anything in there?
geposted Tue 28 Nov 06 @ 11:52 pm
as your card has one input
you can use one timecode
select
"single Timecode as input"
4.1 as soundcard
if you want two need to get somthing like esi udj46
select
4.1 as soundcard
geposted Wed 29 Nov 06 @ 11:34 am
can u tell me wat do i need to use the time coded vinyl..?
geposted Wed 17 Jan 07 @ 5:17 pm
pro virtualdj
1 or two timecodes
a soundcard with two stereo inputs.
ie u46dj , mk2 dj console , presonus firebox
1 or two timecodes
geposted Wed 17 Jan 07 @ 5:20 pm
