Forum: Wishes and new features - Topic: BETTER MASTER TEMPO WITH LOW CPU
Post here the features you would like to see developed in Virtual DJ in the future.
Describe what you want it to look like and for what kind of use (home, parties, clubs...)
VirtualDJ Forum
BETTER MASTER...
Autor - Topic: BETTER MASTER TEMPO WITH LOW CPU -
DJ-PENGUIN
Professional edition user
Posted Sat 19 Apr 08 @ 10:50 pm
If you play with serato scratch live you will understand what i mean.Serato"s timestretch is like on cd players and it uses low cpu!Perfect master tempo
discjockeydoc
Experienced pro user
Posted Tue 29 Apr 08 @ 10:36 am
I agree. When I do use it, I must use the simple algorythm because my tracks won't play smoothly using any of the advanced selections. So, what I do is limit the pitch percentage to 10 or 12 percent, which still sort of sounds like crap, depending on the track.
erxon
VIP Member
Posted Tue 29 Apr 08 @ 1:55 pm
Master tempo is always a demanding process. Making it work live even more,
so if the Serato managed to create a less demanding with better performance
means they either payed some very skilled programmers to create their own
algorithm, or most likely used an existing alogrithm that was expensive as hell.
Btw discjockeydoc, did you try the serato master tempo on your CPU?
If glitches still occour it's obvious that the processor can't handle it, or
even the soundcard set to too low latency.
djsonath
Posted Tue 29 Apr 08 @ 4:35 pm
Dj Penguin is right.
Also one friend of mine has serato.
It uses low cpu indeed and the sound is perfect without any flangers and missing beats.
And the latency is set to higher.
We opened both serato and numark cue and the two programms played together without any problems using about 8-9% cpu in a dual core laptop.
You could hear the difference between the 2 programs in master tempo with the same track.
dizzyrocks2001
Posted Tue 29 Apr 08 @ 7:52 pm
My complaint with the VDJ master tempo is I can hear artifacts and "warble-ee" audio output even when the pitch is set at 0%. It's really noticeable.
discjockeydoc
Posted Wed 30 Apr 08 @ 12:55 am
@erxon
Never used Serato at all, so I'm just sort of relating what happens to me with VDJ's master tempo. My lappy's CPU runs @ 1.6GHz, and I've got 2GB RAM installed, playing audio only. CPU meter on the skin isn't pegged when using the advanced settings in master tempo but sound is utterly detestable, so I've just resigned to using simple MT and tend to think of it as a limitation of my equipment, perhaps. I'll try playing around with the latency, but, if memory serves, I've already done this in the past (with the old MK2 drivers). If I could afford it, I'd probably upgrade the lappy. Thanks for your input, tho, I appreciate it :)
erxon
VIP Member
Posted Wed 30 Apr 08 @ 2:10 am
discjockeydoc wrote :
@erxon
No problem. The thing is the latency plays a cruical role here, the spatialization
and complexity settings too (even I with my dual core 3.0 and low-latency
soundcard I cannot run it on highest settings with low latency - it's just not
possible).
Master tempo produces better results with more samples available to calculate
the new signal, that's why higher buffer (thus latency) and faster processor
are needed to make such calculations in real time.
Btw, on my PC setup I had the 2.6 ghz single core CPU and Creative's Audigy2
sound card, and I had issues running the advanced master tempo. The Serato
comes with it's own dedicated hardware, thus can has lower CPU requirements,
but the latency still has to be set accordingly to the processing complexity.
DJCannonball
Posted Tue 06 May 08 @ 9:50 am
talking about lowering your CPU-usage... i have already posted an idea about CUDA.
http://www.virtualdj.com/forums/88169/Wishes_and_new_features/Use_full_GPU-power_to_run_audio-engine_(CUDA).html
it enables Virtualdj to outsource heavy cpu-duties (like master-tempo-calculations) to a GPU like a NVIDIA 8800 graphicscard!
Think of the possibilities! i think the devteam hasn't seen the light yet. i posted it some weeks ago, still no replies to that :(
VirtualDJ Pro
VDJ HomeEdition
DJC Edition
Trial Version
Sound Effekte
Video Effekte
Tools & Drivers
Users Network
Wiki
Atomix Productions
Disclaimer
Wiki
