As it stands at the moment the major features are:
Text rendered using DirectX rather than the older GDI method.
New GUI using context menus rather than tabs to give enlarged message list area.
Each message can have it's own complete layout and format (everything in the message formatting window) which is inherited from your predefined default. The default can be updated from a message or reapplied to a message too.
Background box has different drawing animation methods.
SMS integration via connected device eg mobile or USB stick.
New message indication on VDJ skin or controller.
Macros now support VDJScript - both to get data and to issue commands (to activate FX or sample when a certain message is displayed for example).
Message list can be scrolled and messages toggled via VDJScript.
Per-vertex colouring with configurable vertex count.
Random colours can be cycled continuously or per message run.
There will be 3 editions of this plugin - a free lite version with limitations, the full version and the full + SMS version.
I've still got some work to do - loading/saving and background box animations have to be done. Everything else though is working though - including the SMS. Future versions will include enhanced SMS functionality - number collation, nickname registration, polls and so on.
geposted Tue 06 Dec 11 @ 8:00 am
Looks very cool!
I like the ability to trigger effects based on a message.
That has a lot of possibilities. I guess it's time to learn VDJscript. If you could also include some examples of said script that would be great.
Any pricing yet?
Any pricing yet?
geposted Tue 06 Dec 11 @ 10:42 am
Plenty of examples available, and I'll put some up too.
It won't be expensive at all - and it won't be tied to an IMEI for SMS users either.
geposted Tue 06 Dec 11 @ 11:10 am
Great work!!
Awaiting the arrival
Huey
Huey
geposted Tue 06 Dec 11 @ 2:09 pm
I cant wait for this, even more so if you can scroll MMS pics
geposted Tue 06 Dec 11 @ 3:03 pm
great work scott
geposted Sun 11 Dec 11 @ 7:48 am
Hey Scott,
Just checking to see how it's going now that the madness of December is over.
Happy New Year!
Happy New Year!
geposted Sun 01 Jan 12 @ 3:25 pm
Currently with second group of beta testers :-)
geposted Sun 01 Jan 12 @ 4:12 pm
Hi Scott,
Does the new version have a default save/load option to get settings/files to load when it is activated?
(This is to go with my Startup Script topic in Wishes and New Features)
Thanks,
B.
Thanks,
B.
geposted Tue 17 Jan 12 @ 4:51 pm
Yeah Scott, We need a Load file option box or tab, maybe several with a check box to pick among them would be good, this way the default file will load on plugin activation...ScrollText, & DJ Cel Text2D...
geposted Tue 17 Jan 12 @ 7:31 pm
At present the new version continually autosaves at every change, and this file is loaded on startup too.
geposted Tue 17 Jan 12 @ 10:27 pm
Cool! Can't wait!!!
geposted Tue 17 Jan 12 @ 10:34 pm
Hi Scott,
So basically it reloads what ever was save from the previous activation.?
If this is what it does, then we need to have a load option tab with boxes where other files can be stored for different venues on activation... just click and check the box with the file name you need the plugin to open on activation or switch too it....
geposted Tue 17 Jan 12 @ 11:11 pm
Hi Scott,
Just my monthly progress check :) (hopefully soon?)
Will you be releasing all 3 versions at the same time?
Thanks,
B.
Thanks,
B.
geposted Sun 05 Feb 12 @ 12:55 pm
I"m still on the case, working through my backlog of plugin releases!
geposted Sun 05 Feb 12 @ 7:32 pm
This could tempt me back to PC, sadly :-(
geposted Fri 10 Feb 12 @ 12:56 pm
There's a Mac version in beta too... although without SMS at present.
geposted Fri 10 Feb 12 @ 6:24 pm
Im really sorry But Ive tried reading through all these posts to find instructions on how to set this up with your phone but i cant find any info or maybe Im just blind lol
geposted Tue 28 Feb 12 @ 11:01 am
The current release doesn't support SMS.
The beta release does but isn't available to all users yet.
geposted Tue 28 Feb 12 @ 11:52 am
Hi genious!
Where can I find the last version? The beta release is online?
Are you thinking to release a pay version?
geposted Tue 28 Feb 12 @ 3:04 pm
