It will be completely free, even the SMS integration. Its only basic SMS mind you.
geposted Tue 28 Feb 12 @ 5:24 pm
"Basic" is what I think many would use anyway and at a price that can't be beat!
geposted Sat 03 Mar 12 @ 10:51 am
Hey guys,
Sorry I am a noob at this stuff. Our previous DJ software (otsav) had scrooling words on it and I have been trying to find something like it to use with VDJ. I found this but have no clue how to install it on VDJ.
I downloaded it. What do I do next?
Thanks for the help guys.
geposted Thu 15 Mar 12 @ 9:30 pm
Just run the exe and it will install. It will then show up in video effects.
It will require you have recent DirectX runtime updates.
geposted Thu 15 Mar 12 @ 10:06 pm
I did run and install it. Said it was installed. But never showed up.
I will have to make sure I have what you said.
geposted Thu 15 Mar 12 @ 10:09 pm
I don't understand. Did you release another version that "1.5.7" from November 2010? Beta o Stable, Where can I try the last version? I use "Scrolltext" every weekend in my Club in Argentina. It really usefull to communicate news to my clients. I'm really thinking to pay a better version if it necessary. I would like to be a beta tester or try a new version of this excelente effect.
Thanks A LOT!!
Alfred, Argentina
Thanks A LOT!!
Alfred, Argentina
geposted Fri 16 Mar 12 @ 10:21 am
v1.5.7 is the latest public version. I'm working on an updated version and it is coming along although I have a few higher priority things at the moment.
geposted Fri 16 Mar 12 @ 2:13 pm
@SBDJ
Hi Scott.
Just one simple question. Is it possible to add static text over whole screen in your Scroll text plugin?
Like this:
Bla bla
bla blabla bla
ok and again
Thank you Tomas
Hi Scott.
Like this:
Bla bla
bla blabla bla
ok and again
Thank you Tomas
geposted Tue 20 Mar 12 @ 11:20 am
Can I try the beta version? I could help you sending details about any errors or improvements.
geposted Tue 20 Mar 12 @ 11:24 am
Tjeck1972 wrote :
@SBDJ
Hi Scott.
Hi Scott.
Hi Tomas, you can use the include video effect by Atomix Production in VDJ named "TEXT". It's very simple and you can add static text on screen, change color, position and size very fast. Otherwise you couldn't change the font.
Tip: if you need more than one static text on screen, duplicate the dll effect in VDJ folder, name "text2.dll" and voilá! Two effect at price of one!
geposted Tue 20 Mar 12 @ 11:34 am
Thank you Alfred, but problem is that i need more texts with some delay between.
Thank you anyway.
Regards Tomas.
Thank you anyway.
Regards Tomas.
geposted Tue 20 Mar 12 @ 11:52 am
Thank you anyway.
Regards Tomas.
Thank you anyway.
Regards Tomas.
So, try "TEXT2D" plugin.
geposted Tue 20 Mar 12 @ 12:14 pm
Sorry this is not that i need. Cant set delay.
Thanks
Regards Tomas
Thanks
Regards Tomas
geposted Tue 20 Mar 12 @ 12:35 pm
@Tjeck1972 > try Scotts scrolltext and the free Firetext plugin both work and look great together, I use this combination in my shows all the time.
You can use the vertical function on Ft and set the scroll speed to zero when your message hits the screen.
Or if it's the same regular message's you want to display all the time use the image tab with a transparent png and save these in the template tab for ease of use for your shows.
geposted Tue 20 Mar 12 @ 1:39 pm
@tayla
Thank you. I will give it a try.
Regards Tomas
Regards Tomas
geposted Tue 20 Mar 12 @ 1:54 pm
Glad I could help, let me know how you get on.
geposted Tue 20 Mar 12 @ 2:38 pm
Scrolltext doesn't support static messages.
You can pause them by setting scroll speed to zero but that isn't much use for this. Let me see if I can add this to the next version.
geposted Tue 20 Mar 12 @ 4:08 pm
I would like to try the new pluging for facebook?
geposted Tue 20 Mar 12 @ 5:55 pm
Thank you Scott.
geposted Wed 21 Mar 12 @ 3:37 am
ScrollText now has a Mac version available for download.
geposted Wed 04 Apr 12 @ 7:01 pm
