now available the second version of the "Pioneer CDJ 100S" skin!
if you have advises for a future version, don't be afraid to expose them!
Take a look :)
Take a look :)
geposted Mon 10 Jan 05 @ 7:37 pm
Please in the future, use the button "modify" next to the button "download" to update your skin.
Great skin !!!
Perfect the button "record" , you are the first one ;-)
*Use "12" size police instead of "10" for title,author,bpm,songlength,hour PLEASE !!
*For the beatlock button, i'd prefer to have the same button as timecode (just to better see when it is on)
* In mode 2 , it is written "cue" for the headphone volume slider (draw an little headphone in white for example)
* In mode 2 , it is written "cue" to select the deck
* For zoom, maybe a button reset, as you want for that
Great skin !!!
geposted Mon 10 Jan 05 @ 7:56 pm
* For the button "automix" you should use leftclick for the action "mix" and the rightclick for the action "automix"
* The drawing "virtualdj" should become a grabzone: it's better as it is in the middle of the skin ;-)
* Add text "Ppitch%" which shows the position of the pitch in percent, next to the bpm
I think that's all :-)
Otherwise great skin again !! Carry on like that
An idea for the author , you can put it a little up ;-) to win space
geposted Mon 10 Jan 05 @ 8:17 pm
Thanks for advises :)
I update the Skin as soon as I can, hi!
geposted Mon 10 Jan 05 @ 8:40 pm
Thanks
geposted Mon 10 Jan 05 @ 8:51 pm
Well new ideas:
I know the real cd player and buttons sync are more "stop" buttons (...equals to eject) So:
on the left of title and author viewer, i see a gray button sync (like existing on the right) above a blue button beatlock
on the right, i see a gray button stop (remove the light and draw a gray square in the middle) above a blue button for time code.
The cue button can now be use to set the first cue
For the future button mix/automix you can write on the bitmap "(auto) mix" instead of the current "automix"
I hope you like this idea
geposted Tue 11 Jan 05 @ 2:48 am
Excuse me don't change the button "cue"
Could you add the drawing of cues too on songpos and wave display (use the same thing as on the default skin for example)
geposted Tue 11 Jan 05 @ 3:15 am
That's a very nice skin. I like the decks.
I think that the wave display is a bit small. It would be better if the wave display could take the length screen.
Good work.
Good work.
geposted Tue 11 Jan 05 @ 8:41 am
I like the first version of this skin, so I can practise a bit without the waveform :)
geposted Tue 11 Jan 05 @ 9:18 am
Have a look in my blog to have an idea of what i tried to explain you.
https://virtualdj.com/blog/djcel/
DJ CEL
DJ CEL
geposted Sat 15 Jan 05 @ 1:55 am
i like your idea ,thanks for the image and i update the skin as soon as i can, hi.
geposted Mon 17 Jan 05 @ 6:48 pm
For the (auto)mix button you can do:
* red light when automix is on
* green light when mix is working
geposted Mon 17 Jan 05 @ 7:40 pm
Well i have improved your skin (add cues), look at my blog again:
If you want my archive tell me here and i give you a link to download it ;-)
geposted Tue 18 Jan 05 @ 6:57 pm
ok, give me the link ...
geposted Tue 18 Jan 05 @ 10:21 pm
http://www.enseirb.fr/~legrandj/virtualdj/CDJ100S.zip
As soon as you have it, tell me please to remove the link
geposted Tue 18 Jan 05 @ 11:08 pm
ok, i download it .
geposted Wed 19 Jan 05 @ 1:46 pm
i'm working for a new version...
geposted Fri 21 Jan 05 @ 1:51 pm
What i dont like to this skin: there is no room for the music/browser.
So even if i use real cdj100's i use other skins for virtual dj.
If you can make the players smaller (enough) (in vertical axis) ...
(there is wasted space)
Or a lighter version (only display, no jog at all)... for users with external controllers / timecode.
geposted Fri 21 Jan 05 @ 2:25 pm
I agree with the height of the cdj100s but it means all recreated . Argh !!
geposted Fri 21 Jan 05 @ 3:22 pm
When I try to switch to this skin I get an error message telling me of an xml error. I have followed instructions and always make sure fonts are copied first. Please advise... Thank you.
geposted Fri 21 Jan 05 @ 6:28 pm
