Which version of VDJ do you have because maybe it's a new function?
geposted Fri 21 Jan 05 @ 8:29 pm
Hi, I like this skin alot, it's very realistic, some changes would be good on both versions,
But what is most important to me is that you keep two seperate skins, one without waveforms which
enhances the realistic side of the skin and allows for good "cd mixing" practice, I really value
that about the first skin, but I would recommend you just perfect it like the cdj7000's by fruit..,
also on with waveform off it would be good if when you press the "eject" button that the deck
in question gets reset, so that no song is loaded, if that's possible?, this could also preserve
memory if no song is loaded (i don't know if that's true).
but however please maintain two skins, one with, one without waveforms, and also if you have time
build on them both,
well done to the creators of skin, I enjoyed useing it but for permanent or proffesional use more work
is needed.
regards, bagpuss
build on them both,
is needed.
regards, bagpuss
geposted Mon 24 Jan 05 @ 5:16 pm
V3: Excellent job !!!! I like your new version very much.
You used my new idea for browser :-)
geposted Tue 01 Feb 05 @ 9:55 pm
djcel thanks I have followed your advices.... :)
I consider that the biggest Wavwform of then one cannot ! :)))
geposted Tue 01 Feb 05 @ 10:43 pm
Great job that's right.
I just think that the waveform is a little ... big. I prefer it smaller.
Maybe with other things above (effects logos or sampler).
geposted Wed 02 Feb 05 @ 6:52 am
I used V3, my only gripe is. I wish you could turn off the scratch mode, and use the jog wheel for pitch bending. I loved the CDJ-700 skin fruit made with that feature. I like everything else on this skin. Great Work.
geposted Wed 02 Feb 05 @ 4:28 pm
Can u make the skin v3 in 1280x800 ??
widescreen!
its the best skin... ;-)
widescreen!
geposted Fri 18 Feb 05 @ 5:39 pm
thanks!
but, like I have written on the FM7 Topic, make 1280x800 skins is "hard"..
'cause take me a lot of time..
Downloads still increase, thanks for this! :D
geposted Sat 19 Feb 05 @ 4:54 pm
I think you need to down scale the players and mixer.., perhaps by as much as 25%, remember there is no harm in having 2 or 3 versions of the same skin, to meet different peoples requirements...
I want to stick with this skin, because it's so good and realistic..., the changes I would like so that I can use this skin out would have to be...
1) decreased players and mixer in size, increase the playlist size and up the font by 2 points..
2) the panel with waveforms is good (the small waveforms), but the colours could be made better, simular to the pionner 7000's by fruit.
3) on the samples section, you've obviously noticed the overlap of graphics, i'm sure you'll agree this could be cleared up.
4) Graphically this skin is very realistic and looks the part, although I think you could enhance the overall look of the skin by brightening it up a bit, hopefully this change wouldn't loss the skins real look.
5) finally that you maybe model a real mixer to create a true to life "pioneer" skin.
This is just my opinion for ideal changes, I love this skin.., very well done ;).
Bagpuss
Bagpuss
geposted Thu 10 Mar 05 @ 6:08 pm
CDJ100S v4 uploaded!
geposted Mon 28 Mar 05 @ 4:00 pm
I have just seen the new update. I like the new things.
Could you add a green light for pitch_reset and the 2 buttons for pitch bend
Maybe on the left of the pitch: two little button
geposted Mon 28 Mar 05 @ 5:08 pm
Sounds good, I'll look forward to useing it :).
geposted Wed 30 Mar 05 @ 6:35 pm
Hey guys,
This is the most beautifull skin of all the Pioneer ones
2 small questions:
- Can it be made for resolution 1280*1024.
- Displaying time might be a little bit bigger.
I love it :)
Regards
2 small questions:
I love it :)
Regards
geposted Wed 01 Jun 05 @ 11:04 pm
@ Johans : If you like the skin as much, why don't you buy the software?
FRUiT94
FRUiT94
geposted Thu 02 Jun 05 @ 12:25 am
I like this skin alot, but it doesn't seem compaitable with the latest version, will their be an update?.
geposted Thu 14 Jul 05 @ 12:31 am
Hello everybody.
I most wanted one file to Pioneer CDJ 100S skin.
The .XML file is missing.
Please evreyone send me if is possible.
Please it is very very importent for me. :-(
Moderated by Lady Cameron
Sorry lonelydj no email address is allowed from a demo user
geposted Sat 05 Nov 05 @ 12:29 am
My Skin is very crazy
geposted Sun 20 Nov 05 @ 6:03 pm
Brendan, I have this skin updated and working for version 3.1, need to update now for 3.2.
If you want, I can send it to you but be aware that it has a screen resolution of 1280*1024 (yeh I changed it )
geposted Fri 25 Nov 05 @ 9:01 pm
CDJ100S V4 doesn't work!!
geposted Sat 31 Dec 05 @ 5:58 pm
If you have the XML error message that tells you that something is wrong in line 0, then just remove this line and it will work, that"s what I did.
I have a working version for 3.1 (3.2 I'm still busy to modify it) Screen resolution 1280*1024 only
geposted Mon 02 Jan 06 @ 4:26 pm
