Kontrol S2
The Left FX section (FX1) controls the effects of the deck 1 and the Right FX section (FX2) controls the effects of deck 2. Use the FX ASSIGN (11) buttons to copy the effects from one deck to another.
Each one of the FX unit offers 2 modes:
The Single Effect mode offers one effect slot but more parameters controls per effect.
The Multi Effects mode offers 3 effect slots (to trigger more than 1 effect at the same time – chained effects).
The selection between those 2 modes is done by pressing DRY/WET (22) button while SHIFT is held.
- DRY/WET Button:
Activates a High/Low pass resonant filter effect.
Hold down SHIFT and press this button to toggle between Single FX and Multi FX modes. - FX1 Button:
In Single FX mode, press this button to activate the selected effect. Hold down SHIFT to control the 1st button of the selected effect (if available).
In Multi FX mode, press this button to activate the effect selected on the 1st FX slot. Hold down SHIFT and press this button to select the next available effect for slot 1. - FX2 Button:
In Single FX mode, press this button to select the previous available effect. Hold down SHIFT to control the 2nd button of the selected effect (if available).
In Multi FX mode, press this button to activate the effect selected on the 2nd FX slot. Hold down SHIFT and press this button to select the next available effect for slot 2. - FX3 Button:
In Single FX mode, press this button to select the next available effect. Hold down SHIFT to control the 3rd button of the selected effect (if available).
In Multi FX mode, press this button to activate the effect selected on the 3rd FX slot. Hold down SHIFT and press this button to select the next available effect for slot 3. - DRY/WET Knob:
Controls the amount of High/Low pass resonant filter effect. Middle (12 o clock) position is "OFF" position (no filter applied)
You can also activate/deactivate the filter by using the DRY/WET Button (22) - FX1 Knob:
In Single FX mode, turn this knob to adjust the 1st parameter of the current effect (if available). Hold down SHIFT and turn this knob to adjust the 4th parameter of the current effect (if available).
In Multi FX mode, turn this knob to adjust the 1st parameter of the effect in slot 1 (if available). Hold down SHIFT and turn this knob to adjust the 2nd parameter of the effect in slot 1 (if available). - FX2 Knob:
In Single FX mode, turn this knob to adjust the 2nd parameter of the current effect (if available). Hold down SHIFT and turn this knob to adjust the 5th parameter of the current effect (if available).
In Multi FX mode, turn this knob to adjust the 1st parameter of the effect in slot 2 (if available). Hold down SHIFT and turn this knob to adjust the 2nd parameter of the effect in slot 2 (if available). - FX3 Knob:
In Single FX mode, turn this knob to adjust the 3rd parameter of the current effect (if available). Hold down SHIFT and turn this knob to adjust the 6th parameter of the current effect (if available).
In Multi FX mode, turn this knob to adjust the 1st parameter of the effect in slot 3 (if available). Hold down SHIFT and turn this knob to adjust the 2nd parameter of the effect in slot 3 (if available).
Quick Note:
Not all effects offer multiple switches (buttons) and parameters (knobs) to adjust their behavior. Therefore it's absolutely normal that in Single FX mode some buttons and / or knobs may do nothing when used.
