Kontrol S2
Native Instruments - Kontrol S2 - Layout
Mixer
  1. CROSSFADER: Blends audio between the left and right channels/decks.
  2. VOLUME: Adjust the output volume of each deck
  3. PFL: Press this button to send this channel's pre-fader signal to the Cue Channel for monitoring. When engaged, the button will be lit.
  4. EQ LOW: Adjusts the low (bass) frequencies of the corresponding deck.
  5. EQ MID: Adjusts the middle (mid) frequencies of the corresponding deck
  6. EQ HI: Adjusts the high (treble) frequencies of the corresponding deck.
  7. GAIN: Adjust the Gain (Trim) of the corresponding deck.
    Press the knob down to reset the gain.
  8. Master VOLUME: Adjust the level of the Master Output.
  9. SAMPLER VOLUME: Adjusts the Master Volume of the Sampler
  10. SAMPLER TOGGLE BUTTONS: Press these buttons to change the HOTCUE buttons to Sampler mode on the corresponding deck. Press again to return to HotCue mode.
  11. FX ASSIGN: Clone the effects from one deck to another. (see EFFECTS)
Deck Controls
