Kontrol S3
Native Instruments - Kontrol S3 - Layout
Mixer CONTROLS
KEY
ACTION
SHIFT (SECONDARY) ACTION
1 CROSSFADER
When on far left position, only sound from the left decks will be heard from the Master Output. When at far right position, only the sound of the right decks will be heard from the Master Output. In all other positions, the audio signals from left/right decks will be blend.
2 VOLUME
Adjust the Volume of each Mixer channel
3 Cue /PFL
Use these buttons to send the pre-fader audio signal of each Mixer channel to the Headphones channel for pre-listening (connection at the front side).
4HEADPHONES VOL
Adjusts the level of the Headphones Output (connection at the front panel).
5HEADPHONES MIX
Blends the signal from the PFL-enabled Mixer channels and the Master Output in Headphones.
6 COLOR FX ON
Enable/disable the selected Color FX on each Mixer channel. When disabled, no Color FX will be applied, regardless the position of the FILTER knobs.
7 COLOR FX KNOB
Apply the selected Color FX to a Mixer channel. No Color FX is applied (off) when the knob is at the center/middle position
8 COLOR FX SELECT
Use these 5 buttons to select a pre-defined Color FX.
FX 1 : Reverb Color FX
FX 2 : Loop Roll Color FX
FX 3 : Noise Color FX
FX 4 : Cut Color FX
FILTER: High/Low-Pass Filter
9 EQ HIGH/MID/LOW
3-Band Equalizer. Use these knobs to cut/boost the frequencies of the Low(Bass) / Mid (Middle)/ High (Treble) Equalizer Band. No adjustment is made when the knob is at the middle/center position
10 GAIN
Use these knobs to adjust the pre-fader output level of each Mixer channel When the knob is at the middle/center position, the track will be at zero dB level (or any other value set in zeroDB VirtualDJ Options)
11 EXT
Use this button to send the signal from the Microphone or AUX Input to Deck 4 as a Deck Line Input
Select which external audio source (Microphone - front connection, or LINE - rear connection) will be routed to the Input of the USB Audio Interface.
12 Master VOL
Adjust the level of the Master Output (connection at the rear panel).
13 BOOTH VOL
Adjust the level of the Booth Output (connection at the rear panel).
Decks
