Native Instruments - Kontrol S3 - Layout
					PERFORMANCE PADS
 The 8 RGB performance Pads offer different functionality depending on the selected mode and the assigned Pads page. See further details in
VirtualDJ Manual - PadsKEY
ACTION
SHIFT ACTION
32 HOTCUEPress this button to assign the 8 Pads to Hotcues page (led will be lit in white).
If in Hotcues, press again to set Pads to Saved  Loops  page (led will be lit green)Press to set the 8 Pads to  Loop  Roll page(led will be lit in cyan)33 SAMPLESPress this button to assign the 8 Pads to Sampler page (led will be turned on white solid).
If in Sampler, press again to set Pads to KeyCue page (led will be flashing white)Press to set the 8 Pads to  Slicer  page(led will be flashing fast in white)34 PADS 1-8Operation depends on the selected page. See  VirtualDJ Manual - PadsOperation depends on the selected page.  See  VirtualDJ Manual - PadsHold
SHIFT down and then use the MOVE and
 Loop  encoders to adjust the Parameters of the selected Pads page (if available)
 					Front & Rear
