I'll check this and post a corrected version tonight hopefully.
Sorry for the convenience, leftclick was working fine at home but it seems there's a problem with the 'is_repeat' event :(
geposted Wed 06 Aug 14 @ 10:17 am
Just have to Vote this in for default skin in Vdj ?
geposted Wed 06 Aug 14 @ 10:59 am
Again very good work from you. Thank you Fruit.
geposted Wed 06 Aug 14 @ 12:13 pm
Thx friends :)
Since :
- it seems there's a 3-clicks hardcoded event in the pitch_reset action
- isrepeat check isn't avoiding this 3-clicks thing (or not working on mouse event)
I can't really avoid an instant pitch reset on a multiple clicks event...
So back to old pitch behavior, but you'll have to tripleclick the button or holding right for 2s.
Since :
geposted Wed 06 Aug 14 @ 2:23 pm
Patch posted
So, two ways to instant reset pitch
- triple left click
- long right click (2s)
And of course the return of the normal one-click slow motion reset behavior.
Sorry for the inconvenience.
- triple left click
geposted Wed 06 Aug 14 @ 3:50 pm
Hello Fruit,
can you please integrate the function "saved loops 1 to 6"
best regards
Werner
best regards
Werner
geposted Thu 07 Aug 14 @ 1:25 am
On the masterplan but no release date yet.
Why 6 ?
Why 6 ?
geposted Thu 07 Aug 14 @ 3:04 am
Fantastic work and a lot of good ideas.
Many thanks for this masterpiece.
geposted Thu 07 Aug 14 @ 4:18 am
ten are better but where is space
Why 6 ?
Why 6 ?
I'll see that ^^
Thx @music ^^
Thx @music ^^
geposted Thu 07 Aug 14 @ 4:58 am
I think he means that save loop (4 beats etc..) to cue button 1 - 6 (watchable on skin)
Would be nice if the "save loop" just takes the next empty cue..
geposted Thu 07 Aug 14 @ 6:21 am
I means saved loops like them
not to cue Button
geposted Thu 07 Aug 14 @ 8:02 am
If you tell that a menu would fit, well I can do 20 loops lol.
geposted Thu 07 Aug 14 @ 8:47 am
That is a nice suggestion.
But I would like to use the loop saving more "on the fly" , thats why I would like to save on an empty cue right away.
Think its an easie to edit when you have the loop saved on a cue that way ?
Is this a programing issue in vdj to save directly to Hot Cues or could this be made with macros ?
geposted Thu 07 Aug 14 @ 8:56 am
What I can do is :
- a header that would be the only menu, to choose/show the number of the loop
- leave the buttons as they are now, but acting on the chosen loop
So you can rec, save and load on the fly just as now AND quickly select the loop you want to act on. AND without creating thousands of buttons / having a boring menu on each button.
Cue-loops... I don't know if I can manage that well. Have to brainstorm :)
geposted Thu 07 Aug 14 @ 9:02 am
This is not a mockup :)
Like it ?
Like it ?
geposted Thu 07 Aug 14 @ 9:51 am
Hi Fruit,
for my own use I did something like this:
If loop selected, you can save with right click. After you done this, the small icon with the loop Nr. gets a background fits to the deck (e.g. blue).
Would be great, if we could display this behind the waves in another color, like the cue-points-Nrs.
I think this is better than another menu, cause we need optical feedback in my opinion.
Just a suggestion, hope it helps ;o)
geposted Thu 07 Aug 14 @ 11:47 am
I don't know if there's a trick to show loops on songpos but I'll try to experiment a bit.
geposted Thu 07 Aug 14 @ 1:22 pm
Like it ?
Like it ?
Like? That looks downright illegal - course we're gonna love it :)
geposted Thu 07 Aug 14 @ 2:39 pm
