Last night
Thanks Fruit
Thanks Fruit
geposted Sat 02 Aug 14 @ 3:29 pm
You're welcome, but you must have picked up the wrong pic, I see 0.3 on this one.
Anyway, thank you for using this skin :)
geposted Sat 02 Aug 14 @ 3:38 pm
First of all Fruit, thanks for the skin. It's all you could ever want in a skin. My question is about the "save" option. What exactly gets retained when you "save." I make a lot of customizations and it seems like when I start the program I have to re-select some options. Thanks in advance... really appreciate the work!!!
geposted Sat 02 Aug 14 @ 4:03 pm
Fruit wrote :
You can already have both three display times when enabling the 'double height' forms in the forms top left menu. Isn't it enough ? If no, where do you think those times should show ?
The double height works fine. I didn't see it before. You could also make the font a bit smaller and put only elapsed and remain in the same spot without double height.
Thanks again,
DJ James
PS again. Also I noticed that when double height is engaged that the show_music and show_video buttons disappear.
geposted Sat 02 Aug 14 @ 4:23 pm
This item's purpose is to write the vdj options in settings.xml, what is actually done when you close the software only. I use it because I sometimes crash when working on my skin. I let it here in case it could be usefull to others.
Most of the states of the skin will remain when closing/opening the software, with a few exceptions. Those exceptions were a choice of me, for example, I don't want users to start the program and not see the title/artist and be forced to search what option they triggered last night when they were drunk (lol).
But some of them will anyway remain in 0.5, mainly, the vu-meters color, the cover if on wheel, key info in deck's screen.
geposted Sat 02 Aug 14 @ 5:25 pm
I'll check this when I come back home, but I believe it doesn't happen to me...
geposted Sat 02 Aug 14 @ 5:29 pm
It happens here too. I believe it's just because the browser area is made smaller.
The vertical icons are a problem when there is only a small browser height because they either disappear or they sit on top of each other.
I have mentioned this many times but Atomix don't seem to care. The buttons are better placed along the top bar of the browser.
The best solution would be to offer the user a choice of left/right/top/bottom like the Windows task bar.
geposted Sat 02 Aug 14 @ 5:58 pm
Thanks bro...
geposted Sat 02 Aug 14 @ 10:48 pm
This is not as simple I believe :)
I have to check at home to confirm that, but :
- At the VERY FIRST launch of vdj, those icons are not present !
- They pop up only if you go to the browser menu above the font size buttons and choose on of the items 'show music only', 'show video only', 'show karaoke only'. AFAIK those buttons won't ever disappear, even if you uncheck all three items.
- When in my skin you change the stance to show double-height forms, then it brings to you a brand new fresh browser. You may have noticed that the side panels were to set again, as well as the panel that shows covers above the filelist. The jukebox views behave the same, it brings two fresh new browsers.
So in my skin there are 5 browsers and all of them have their own settings / pos. You just have to re-check one of the three menu items in each. Then it would show the buttons. Not sure it is an intended behavior, or the 'not showing icons at first launch' is a bug.
geposted Sun 03 Aug 14 @ 2:17 am
So I'm at home now and just checked :
As I said at the very first launch there are no icons.
As soon as you check one of the items 'show music', 'show video', or 'show karaoke', buttons will appear.
They will remain until you :
- uncheck all three items
- close / relaunch vdj
Then they will pop up again once you check one item.
Each browser has its own properties / states so the above is to be considered for EVERY browser of my skin.
geposted Sun 03 Aug 14 @ 10:34 am
jamesvanek wrote :
2) Not sure if you can do this in the skin or if it is a VDJ issue but it would be great if the view_options 'showmusic' and the view_options 'showvideo' buttons could change colors when activated. Messes me up everytime when I forget to switch it back.
Done.
geposted Sun 03 Aug 14 @ 10:43 am
I can easily make those 'show' buttons disappear.
First of all, I always have 'show music' selected so I would always expect to see the buttons - yes?
All I have to do to make them disappear is select the double height waveform (which forces the browser to be lower). The buttons are gone.
I still have 'show music' selected. I can restart and the buttons are still missing.
Believe me, I have seen the buttons disappear right in front of my eyes when I resize a skin or use one which has a small browser height.
I have also seen the buttons being displayed one on top of the other when the browser is small.
FRUiT, if you are using a 4:3 screen then you have more vertical height than users with a 16:9 screen - maybe that's why you still see them.
geposted Sun 03 Aug 14 @ 12:32 pm
I have a 1440x900 16:10 rez at home.
Not exactly a 16:9 ratio but close.
But I found someone who has a 1920x1080 screen I'll check there to be sure, but it will be in two weeks...
Did you try to check an item WHILE you don't see the buttons (let's say in fullscreen mode) ?
I ask this because, imo this is a bug : the menu stills always show the same items checked, BUT checking one of them would make the buttons appear (but you're right if the window is too small they disappear, but the window has to be ridiculously small in height). Can you confirm ou infirm this please ?
geposted Sun 03 Aug 14 @ 3:13 pm
-- v0.5 --
- FIX: pitch reset stills visible in mirrored stance
- FIX: holding stop-to-unload in jukeboxes set to 100ms
- FIX: key font clipping in key panel
- FIX: Effect button 2 not showing text
- FIX: browser: played song icon glitching over video icon
- hot cues monitor on jogwheel
- loop monitor on jogwheel
- new alternate art view on jogwheel
- persistent vu-meter scheme / wheel cover art
- can choose RPM in wheel sub menu
- can restore hidden song infos on the fly
- can flatten ui (++ buttons)
- can show EQ in videomixer
- big video mode in videomixer
- jogwheel can show video (WIP)
- filters in videomixer
- master effect in videomixer
- can load / save deck-sets
- song infos in jukeboxes
- remaining time blinks in jukeboxes
- waveview: perdeck: ear-line moved left
- waveview: perdeck: center improved (WIP)
- waveview: brightness dimmer
- legend in master's monitor
- big, much more clickable cues on songpos
- hot cues rightclick behavior redefined (click : goto | hold : delete)
- flattened transport lights off when deck is empty
- screen's key info remember it's state (independantly)
- every vertical vu-meter is clickable
- every vertical vu-meter follows color scheme
- beat grid adjusting buttons
- contrasted browser buttons when clicked / selected
- up to 4 master effects
geposted Tue 05 Aug 14 @ 5:42 pm
Your new skin update is VDJ Porn! I love it so far
geposted Wed 06 Aug 14 @ 4:34 am
ROFL ! Thx, bro !
geposted Wed 06 Aug 14 @ 4:46 am
Just installed .05, I cant get the pitch reset button to work, programming issue? or did I somehow disable it
geposted Wed 06 Aug 14 @ 9:24 am
beat me to it
geposted Wed 06 Aug 14 @ 9:50 am
OMG I forgot a line in changelog...
I changed the behavior of this button because I read that some guys don't want the doubleclick feature.
So, to instant-reset the pitch you now have to hold RIGHT for 2sec.
Erf and left click won't do anything now :( that's a bug :(
geposted Wed 06 Aug 14 @ 9:57 am
I'll program one of the custom buttons for now!
geposted Wed 06 Aug 14 @ 10:13 am
