I need Ableton Link in VDJ.
geposted Mon 09 Jul 18 @ 6:12 am
are we Ableton Link'ed yet? How bout now? I don't want to go back to Traktor. Pretty please. :)
geposted Wed 01 Aug 18 @ 2:55 am
I need Ableton Link also for Lightrider
geposted Tue 18 Sep 18 @ 8:27 am
If you're DJing professionally (your web site tells me you are) then you need a Pro license.
geposted Tue 18 Sep 18 @ 8:49 pm
Another upvote for Ableton Link.
geposted Tue 09 Oct 18 @ 3:36 pm
Same here....... Link please
geposted Sat 27 Oct 18 @ 7:32 am
There are currently 170 apps using Link, including Traktor, Serato, Resolume, Madmapper, Maschine, Reason etc.
geposted Sat 27 Oct 18 @ 4:19 pm
Available in Early Access.
To install, go to Options->Extensions and look for the Ableton Link plugin.
geposted Thu 08 Nov 18 @ 4:17 pm
So presumably this works (sync) in both directions - master and slave?
geposted Thu 08 Nov 18 @ 5:28 pm
There is no master or slave in Ableton Link. All links are synced with each other, the one joining a session will be synced with the session at that point.
geposted Thu 08 Nov 18 @ 5:31 pm
Thanks. I'm just using the terms to ascertain whether VDJ can now sync to an incoming clock.
Historically it always needed to be master (ReWire etc).
So once the add-on is installed, how do we use it? [later] OK, found it. It's listed as an effect.
geposted Thu 08 Nov 18 @ 5:35 pm
if you frequently use it you'll probably want a custom button or button on your controller, so then it would be
effect_active "Ableton Link"
geposted Thu 08 Nov 18 @ 5:59 pm
From the Ableton site:
"Please note that on Windows machines, Link requires that you use ASIO audio drivers. Non-ASIO drivers are not supported."
Ah, that'll be why I wasn't getting anywhere just now.
geposted Thu 08 Nov 18 @ 6:13 pm
In Ableton Live it's indeed only available using ASIO, but in VDJ it's still available with WASAPI as well (although stability will vary much more depending on the device and if you're using exclusive mode or not)
geposted Thu 08 Nov 18 @ 6:53 pm
There is no WASAPI in Ableton Live anyway. It's been requested by users, but.....
geposted Thu 08 Nov 18 @ 7:10 pm
I can't find Ableton Link plugin - any pointers?
geposted Sat 10 Nov 18 @ 4:58 pm
It's under Effects, Audio FX
geposted Sat 10 Nov 18 @ 5:02 pm
Hello,
I can't find the plugin on the website or the Software anyone got a link or something?
Best Regards!
Best Regards!
geposted Sat 10 Nov 18 @ 5:05 pm
Bronsi98 wrote :
Hello,
Best Regards!
Best Regards!
geposted Sun 11 Nov 18 @ 4:10 am
Nice!! Definitely gonna give this a try tonight.
geposted Mon 12 Nov 18 @ 2:35 pm
