Forum: VirtualDJ Skins
Topic: CDJ 100S v2 - Page: 1
now available the second version of the "Pioneer CDJ 100S" skin!
if you have advises for a future version, don't be afraid to expose them!
Take a look :)
geposted Mon 10 Jan 05 @ 7:37 pm
Please in the future, use the button "modify" next to the button "download" to update your skin.
Great skin !!!
Perfect the button "record" , you are the first one ;-)
*Use "12" size police instead of "10" for title,author,bpm,songlength,hour PLEASE !!
*For the beatlock button, i'd prefer to have the same button as timecode (just to better see when it is on)
* In mode 2 , it is written "cue" for the headphone volume slider (draw an little headphone in white for example)
* In mode 2 , it is written "cue" to select the deck
* For zoom, maybe a button reset, as you want for that
* For the button "automix" you should use leftclick for the action "mix" and the rightclick for the action "automix"
* The drawing "virtualdj" should become a grabzone: it's better as it is in the middle of the skin ;-)
* Add text "Ppitch%" which shows the position of the pitch in percent, next to the bpm
I think that's all :-)
Otherwise great skin again !! Carry on like that
An idea for the author , you can put it a little up ;-) to win space
Thanks for advises :)
I update the Skin as soon as I can, hi!
Thanks
Well new ideas:
I know the real cd player and buttons sync are more "stop" buttons (...equals to eject) So:
on the left of title and author viewer, i see a gray button sync (like existing on the right) above a blue button beatlock
on the right, i see a gray button stop (remove the light and draw a gray square in the middle) above a blue button for time code.
The cue button can now be use to set the first cue
For the future button mix/automix you can write on the bitmap "(auto) mix" instead of the current "automix"
I hope you like this idea
Excuse me don't change the button "cue"
Could you add the drawing of cues too on songpos and wave display (use the same thing as on the default skin for example)
That's a very nice skin. I like the decks.
I think that the wave display is a bit small. It would be better if the wave display could take the length screen.
Good work.
I like the first version of this skin, so I can practise a bit without the waveform :)
i like your idea ,thanks for the image and i update the skin as soon as i can, hi.
For the (auto)mix button you can do:
* red light when automix is on
* green light when mix is working
Well i have improved your skin (add cues), look at my blog again:
https://virtualdj.com/blog/djcel/
If you want my archive tell me here and i give you a link to download it ;-)
ok, give me the link ...
ok, i download it .
i'm working for a new version...
What i dont like to this skin: there is no room for the music/browser.
So even if i use real cdj100's i use other skins for virtual dj.
If you can make the players smaller (enough) (in vertical axis) ...
(there is wasted space)
Or a lighter version (only display, no jog at all)... for users with external controllers / timecode.
I agree with the height of the cdj100s but it means all recreated . Argh !!
When I try to switch to this skin I get an error message telling me of an xml error. I have followed instructions and always make sure fonts are copied first. Please advise... Thank you.
50%
