if you have 2 monitors active and you load a skin where the logo is not a specific size, then vdj will give you a skin error.
i've tried it with overflow ex.
if monitor 2 is off, then it will load just fine.
geposted Sun 23 Nov 08 @ 1:21 pm
Do you have the same resolution in both monitors?
geposted Sun 23 Nov 08 @ 3:01 pm
Sorry to go off topic, but this is the 100.000th topic on VirtualDJ Forums :-)
geposted Mon 24 Nov 08 @ 2:45 pm
laptop: 1440*900
ext monitor: 1680*1050
resolution has nothing to do with it.
it's a bug that needs to be fixed with in the code.
geposted Tue 25 Nov 08 @ 6:44 pm
yey
