So i got the BCD3000 andddddddddddddddddd it doesnt work with vista (32 bit).
I have:
- Downloaded Vista driver off website
- Messed with a bunch of config options
-Got some sound that just quits after about 10 sec. (up to about 1 min at one point)
However:
- the controller aspect works spot on, very responsive, just the external soundcard option does not work.
- Under the Sound setup and ASIO driver, do you use the asio panel then selected the BCD3000 or just straight the BCD3000
Any help would be great!!
I have:
However:
geposted Mon 24 Nov 08 @ 4:12 pm
OK i gave up and installed the BCD3000 on an XP machine, Works great.......... except 1 think
The feature to preview a song on your headphones wont work, when i hit the cue button it switches in VDJ but still all i hear is the master through my phones, help pleaseeeeeeee!!
geposted Mon 24 Nov 08 @ 7:04 pm
You must switch in Sound Setup to:
INUPTS: None
OUTPUTS: Headphones
Soundcards: ASIO Driver
ASIO Driver: BCD ASIO
INUPTS: None
OUTPUTS: Headphones
geposted Wed 26 Nov 08 @ 5:18 pm
yes, it can work on Vista.
1) when you install the bcd3000 change the compability to XP
2) open VDJ (version required VDJ 5.2)
3) configuration
4) remote control
5) look for the bcd 3000 image
6) right click on it, and "activate"
7) OK
and that´s it
I all ready did it on my computer
with Vista and it works
good luck!
lettherebelight
3) configuration
4) remote control
7) OK
and that´s it
good luck!
lettherebelight
geposted Wed 17 Dec 08 @ 1:32 pm
