Topic: CM200usb as sound card ?
Can I use the CM200usb with my timecode setup with my DNS3500 or do i still have to sue an external soundcard ?
geposted Wed 26 Nov 08 @ 9:41 am
The CM200USB can not be used for Timecode support. It does have an output to the computer for recording to the computer .. not sending a timecode signal to software.
So how does it work with the DMC2 controller ?
The CM200USB will work as an output sound card for VDJ. It will work with controllers just fine, but is not suitable for use with a timecode solution unless you use a different soundcard altogether.
Oh ok thanks. I am playing tomorrow night ane there is a setup in place at the venue which uses VDJ with the usb mixer and controller. I wanted to hook up my dns3500 aswell so i can run VDJ as well on timecodes. how can i do this...????
To: The Forum Moderator
I'm just new here on this forum.
I don't know where to start, posting about my inquiries on my question.
Can VDJ works with my Serato SL 1 as a soundcard?
I've Tried to use it but it works only for about 10mins. and it stops working.
What to do?
Needs advice.
Thanks and more power.
DJ Kid Andro
xxxxx@yahoo.com
Virtual DJ work good with Serato SL 1 soundcard and its TimeCode, if you have some setup problem please contact E-service
https://virtualdj.com/contact/
PS.
"No license user" can't write personal Email, Msn, Skype, MySpace and any other personal contact details in the forum.
