Mabye its a stupid question but i would like to know,if i can use VDJ 5.2.1 on my two laptops or i have to get a new copy or an older version for one of the laptops..thnxxx
geposted Wed 26 Nov 08 @ 5:39 pm
Yes, your EULA gives the right to use the program on up to two PCs.
geposted Wed 26 Nov 08 @ 5:46 pm
thnxxxxx a lot tearem up...just one more question...Even after new windows intallations???
geposted Wed 26 Nov 08 @ 5:56 pm
Yes
geposted Wed 26 Nov 08 @ 5:57 pm
From VDJ EULA,
PERMITTED USE AND RESTRICTIONS
You are granted one license to:
- install and use the Software on one computer.
- install and use the Software on a second computer, if this computer is normally used by the same person and the Software will not be used on both computers at the same time.
- make back-up copies of the Software for archival purposes.
This license does NOT allow you to:
- rent, lease, sell, lend, distribute, publish, bundle or sublicense the Software or any part of it.
- rent, lease, sell, lend or distribute hardware on which the Software is installed, unless specifically authorised by Atomix.
- electronically transfer the Software from one computer to another or over a network.
- decompile, reverse engineer, disassemble, or otherwise reduce the Software to a human-perceivable form.
- modify the Software or create derivative works based upon the Software.
Regards;)
Regards;)
geposted Wed 26 Nov 08 @ 7:48 pm
