Could the dev team save the value of "headphone_volume" in the registry of windows before closing VDJ and start VDJ with this value to prevent from destroying the headphone (actually init the slider at 4096)
OR my 2e idea:
when selecting a drawing with a headphone in the sound card config, force to put the slider to 0 when VDJ start
OR my 2e idea:
geposted Tue 08 Feb 05 @ 2:51 pm
Moreover,is it possible to set the same behavior as for the main crossfader to "headphone_crossfader" and add in the setting an option (on/off) to hang "headphone_crossfader" to "crossfader"
It's very great when you only want to mix with headphone
geposted Wed 09 Feb 05 @ 12:17 am
Well yesterday, i tried my plugin headphone v2.0, in live during a party, using this idea and finally it's not enough powerful. I had to pre-listen on my mix table yesterday but the best would be to directly pre-listen the master output from the software
For the crossfader behavior in headphone, forget it's something so complicated as with the pre-listen of the master, the problem is solved. However keep the idea of hanging the both crossfader
geposted Sat 12 Feb 05 @ 9:35 pm
