I UPDATED MY VDJ LE & NOW ALL MY BPMS IN MY PLAYLIST ARE DOUBLING FROM WHAT THEY ORIGINALY WHERE??
geposted Fri 28 Nov 08 @ 12:46 am
Go check the Config->Options and look at the setting for Allow BPM<80 and make sure it is Enabled [which is the default in the LE editions]
geposted Fri 28 Nov 08 @ 7:35 am
I DONT HAVE A CONFIG BUTTON ON MY LE.
geposted Fri 28 Nov 08 @ 2:03 pm
Which LE were you using before?
And had you run the 20-day trial and made changes?
geposted Fri 28 Nov 08 @ 4:13 pm
NO I HAVENT USED THE TRIAL & I WAS USING THE LE THAT CAME WITH THE RMX I WENT TO SOFTWARE UPDATES & UPDATED THE LE.
geposted Sat 29 Nov 08 @ 5:09 am
