I got one laptop and one desktop pc and i dont know how to connect them. Is there a posibility to do that or i have to buy another extensions.IF there is a possibility can u tell me how to do that and what is needed for that procedure THX
geposted Fri 28 Nov 08 @ 8:23 am
Why,
What are you trying to achieve mate.
geposted Fri 28 Nov 08 @ 8:36 am
If you want to connect them for file sharing you will need 2 network cards and lan cable.
geposted Fri 28 Nov 08 @ 9:06 am
well i am trying to connect them so i can use virtual dj on both computers. i have yamaha amplifier DSP-A2070 if that can help a bit
geposted Fri 28 Nov 08 @ 4:01 pm
You will need Pro license for that, your demo will expire in 20 days ;)
geposted Fri 28 Nov 08 @ 4:39 pm
