Topic: Lost Playlist Data. Why?
Anyone,
After a few weeks, I've lost the data for my songs, even if I don't move the folder on my hard drive. This has been going on for a while, but with some tracks. Now all my tracks info (bpm & song don't play in listen mode) is gone.
I tried the fix and check and nothing works to link the files. This also occurs in the history folder.
Does anyone know why this occurs and how to fix it? Thanks.
FLeX
geposted Fri 28 Nov 08 @ 8:45 am
Which format do you use?
I hope I understood your question. I use VDJ to scan. Then I save my playlists.
Thanks.
No, what format of files do you use mp3, video?
For music, I would say 60% are wav & the remainder are mp3. One more thing, I notice my virtual folders are still good to go.
It's only my playlist & history the data is gone. I would have to do a search to find the original.
Thanks.
Guys,
I might have figured out the issue.
I believe it is the drive letters. The drive letters changed. My hard drive is an external and it has its own dedicated usb, but I did uplug another usb to connect a flash drive. When I replug the other usb it changed the drive letters.
It doesn't happen alot, but this could explain why sometimes I loose data. I'll pay attention to this issue on my side.
yep, gotta remember to put ehd into the same port everytime....
