I wanted to create my own midi configuration for the BCD3000 and i cant figure out how to get it to work with the red LED's does anyone know how to get that aspect of the BCD to work???
Thanks
Thanks
geposted Fri 28 Nov 08 @ 5:16 pm
MIDI mapping doesn't currently support output for LEDs, displays and so forth. A custom mapper (DLL) is required for that.
geposted Fri 28 Nov 08 @ 7:18 pm
does anyone know when using auto learn w/ bcd3000 how to make it so that if say the scratch button is pressed than the other buttons functions change too, ex. when CUE a is pressed the jog wheel on deck A can be used as broweser selection... etc
geposted Sat 29 Nov 08 @ 8:12 am
You can't. Same as above, you would need to write a mapper.
geposted Sat 29 Nov 08 @ 10:39 am
How do you write a mapper? A link or something would be great....
Probably getting Pro Edition for xmas so pumped for the Moramax mapper, but until then i need a solution.
geposted Sat 29 Nov 08 @ 5:20 pm
