So I'm having an issue with my RMX. I haven't been hanging out on these forums much since they updated it (not related to change but the change in the forums came while I was "absent"). Anyways the newer search is difficult to use so I hope I don't get flamed if this is a known issue.
On my RMX, on the "left deck", when I press the play/cue button...the track skips sometimes. It almost looks like it's trying to sync the track to the right deck but that isn't the case. So...the track doesn't really start where it's cued up to. This only happens on the left deck...and not the right one. I updated the driver but this still happens.
Any help or anybody else out there having the same issue...?
geposted Sun 30 Nov 08 @ 3:13 am
Do you use VDJ that came with RMX or VDJ Pro?
geposted Sun 30 Nov 08 @ 10:06 am
Well my license is the limited one but I typically use my rmx on my buddies/companies computer who has pro. I'll test it with my home one when I get back home latter. I'll probably end up getting my own license sometime soon but right now I'm testing out all the dj software out there. Serato looks tempting but I'm still leaning to stay w/VDJ.
geposted Sun 30 Nov 08 @ 11:57 am
Thanks Alf. Its been driving me nuts. I've used the VDJ regcleaner to fix it. After a while it gets enabled, anyone know why?
-David
-David
geposted Mon 01 Dec 08 @ 2:34 pm
Hm, that is strange, did you closed VDJ properly? Sometimes you need to wait a bit longer when it closes to save all information collected during work.
Also, do you have any Antivirus or Antispyware software like Spybot that might prevent registry change?
geposted Tue 02 Dec 08 @ 5:22 am
Hello dj_ville,
1) Do you use VirtualDJ 5.2.1 or an older version?
2) Are you in Vista, or on XP, or on Mac OS?
3) Have you stopped the CPU hungry ressources which may disturb VirtualDJ?
geposted Tue 02 Dec 08 @ 5:24 am
You can test your console as a MIDI controller. That way you could notice if the Play button is behaving differently than the others. If so, it could mean a hardware problem.
This FAQ will tell you how to do it:
http://ts.hercules.com/faqs/eng/her_eng_00353.pdf
geposted Thu 04 Dec 08 @ 1:58 pm
