This is my first issue with VDJ. I am using 5.2.1 and when playing a video it flashes back to the previous video that was played on that deck. For example the first video played is disturbia on deck 1. When the second video is played on deck 1, say cha cha slide, scenes from disturbia will randomly replace the cha cha slide video. Has anyone experienced this? I am on XP SP3.
Thank you
Thank you
geposted Sun 30 Nov 08 @ 10:44 pm
Sounds like you got video linking turned on, check your user guide on the steps to disable this option if you don't want to use it. Then you will need to right click the file that currently is has a linked video like "cha cha slide" and remove the link.
geposted Mon 01 Dec 08 @ 12:06 pm
