Hi guys, i am having a problem with my laptop,when i stop playing any music or pause it, i still hear a buzzing sound as in engine noise on my speakers,is there a way to fix this problem?
Cheers.
Cheers.
geposted Sun 30 Nov 08 @ 10:48 pm
If the sound is gone when you run on battery then it is a Ground Loop Problem. You can isolate your ground pin on Power cable as a quick solution on a gig, but it is the best to get Ground Loop Isolator:
http://www.radioshack.com/product/index.jsp?productId=2062214
geposted Mon 01 Dec 08 @ 4:02 am
when its on battery it's still producing the humming sound.Any other solution a part from the ground loop isolator?
geposted Mon 01 Dec 08 @ 5:58 am
How is your system configured? Inputs outputs, etc?
Does the noise disappera when you turn down the volume on the channel your laptop is connected to?
What sound card are you using or are you using the headphone jack from your laptop?
Cheers,
Roy
Cheers,
Roy
geposted Mon 01 Dec 08 @ 6:28 am
If you have ground loop problem, you will have noise even if you lower down level of laptop as noise is coming thru ground, not Sound output.
geposted Mon 01 Dec 08 @ 7:04 am
Agreed, I'm just trying to get a look at the bigger picture...
I too suffered this problem. Unplugging the mains lead from the laptop stopped my noise. I ended up buying a 3rd party power supply which solved my problem.
One thing ogked needs to checl is if the problem goes away if he unplugs the mains adapter completely and not just from the back of the laptop...
Cheers,
Rpy
Cheers,
Rpy
geposted Mon 01 Dec 08 @ 9:41 am
im using 2 icdx and a dxm01 mixer all connected to my laptop.
geposted Mon 01 Dec 08 @ 6:15 pm
