After buying several laptops over the past years the first thing I did was to follow the advice of Black Viper and others, so that hungry Vista wouldn't be so heavy on resources, however i have found this can cause many problems. Recently i was submitting crash reports which were recognised as external to VDJ so i reinstalled Vista with all updates and also Virus/ spyware software and also a prog called PC Doctor and then VDJ. I didn't make any of the recommended adjustments to the Laptop, I didn't switch any software off whilst gigging and the last 8 gigs have been trouble free. As often said " If its not broke don't fix it "
geposted Mon 01 Dec 08 @ 3:35 am
There is true in that statement. Often people in those tips advice to disable a lot of services, some of them might needed by user like network, sharing etc.
On VISTA you can disable for sure:
Sidebar
UAC (User Account Control in Control Panel>User Accounts)
Aero
Windows Defender, Firewall and System Protection
Fix Swap file to same size, like 2 or 3GB
Disable Disk Defragment Scheduler
Hope this helps
Sidebar
Aero
Hope this helps
geposted Mon 01 Dec 08 @ 4:50 am
Your correct about this. I have three vista computers and have deactivated very little in two of my computers. None in the third.
A matter of fact I installed more to help perfect how I like VDJ to run ( not because it was needed ).
geposted Mon 01 Dec 08 @ 9:05 am
Don't disable UAC.... why does everyone on this forum think this is a good idea? Especially on a dedicated gig machine, when are you ever going to get a UAC prompt? Does Virtual DJ write anything to Program Files other than the initial installation, nope.
geposted Mon 01 Dec 08 @ 9:19 am
Andrew you may think it's a good feature, and it may be,
but there are some people, including myself, that think it's one of the most annoying things ever.
geposted Mon 01 Dec 08 @ 9:26 am
If it's on a dedicated gig machine and you're only using Virtual DJ and your web browser, UAC is never going to interfere. I remember reading last week that a DJ was asked to play a track from a USB pendrive and it contained a virus. Had UAC been available, in theory, the virus should not have been able to cause such widespread damage that a format of the laptop would be required as it would not have access to change any system settings.
I suppose a lot of how annoying UAC is comes down to how badly some older software has been designed (compatibility), or how often the user wishes to add and remove software. A trick is to install such applications into C:\Users\Public\Documents. I don't find UAC too obtrusive and only encounter it when I run CCleaner or O&O Defrag, it takes less than a second to press ALT + C to confirm I want to give the program administrator rights.
I guess a lot of my issue is that I'm generally the person who is asked to fix friends/family computer problems caused by the user themselves by disabling their security but of course everyone is welcome to their own preference.
geposted Mon 01 Dec 08 @ 9:53 am
UAC will not save you from viruses and trojans, believe me, they first write code to get around it ;)
geposted Mon 01 Dec 08 @ 10:20 am
what is the UAC thing al abowt?
geposted Wed 03 Dec 08 @ 8:31 am
User Access Controls. It is a program that asks "Are you sure you want to allow this" in Vista. Turning it off makes a difference on how the machine performs.
geposted Wed 03 Dec 08 @ 8:38 am
